Fairly New Battery but car will not start.
Old Oct 5, 2008 | 04:24 PM
BigL0U's Avatar
Doesnt even crank. Turn of the key and nothing but one click. 60K miles on it. where should i start?
should spark plugs be replaced every 30K?
Old Oct 5, 2008 | 04:26 PM
robbiem's Avatar
check your battery terminals
Old Oct 5, 2008 | 04:29 PM
KCMAXX's Avatar
KC's FINEST
Tap the starter with something while someone turns it over.
May be the solonoid.
Old Oct 5, 2008 | 04:36 PM
BigL0U's Avatar
terminals are good... what else should i consider with this symptom? starter...cables...?
Old Oct 5, 2008 | 04:39 PM
BigL0U's Avatar
i should probably start learning how to take all that apart BUT id like to know if theres something i should specify to a shop to look into with this matter.
Old Oct 5, 2008 | 04:54 PM
pmohr's Avatar
No more Maximas...
You say fairly new battery, but have you checked to see whether or not it's currently holding a charge?
Terminals are good as in tight, completely corrosion free?
Check the connections to the starter, and if those are good and your battery is charged, try jumping the starter manually.
Old Oct 5, 2008 | 05:49 PM
BigL0U's Avatar
no corrosion. to be honest im not sure where the starter is. ill look into that. otherwise ill specify to the shop to check the starter. mostly concerned with what you guys may suggest is what the shop will as well.
Old Oct 5, 2008 | 05:50 PM
pmohr's Avatar
No more Maximas...
And the battery's charge? Have you even tried jump starting it?
Old Oct 5, 2008 | 06:23 PM
Blitzfist's Avatar
alternator??
Old Oct 5, 2008 | 07:45 PM
CMax03's Avatar
1.Do you have a battery/electrical system tester?
2.What is a fairly new battery?
3.Measure battery voltage with a Volt ohm meter...
4.Is this a maintenance free battery?
If your car was running b4 this battery swap, I would definitely point all my attention to that fairly new battery! Maybe you just need to charge it for 24 hrs!
Old Oct 5, 2008 | 08:07 PM
Max_5gen's Avatar
Auto or manual? year? Do your lights go dim when you turn the key into START? If it is auto - put it in N and try again.
Anyway, sounds like starter motor. If you open your hood and ask someone to turn key to ON while listening for sounds below air filter and you hear loud click - it is definetly starter motor.
Old Oct 8, 2008 | 01:43 PM
Crasher's Avatar
Bad KC... Newer starters these days cannot take that tapping. You will break the magnets. Better off to check the battery first, then take the starter off and have it checked. In my opinion though if the battery is good for sure and it will not even turn over... Bad starter
Old Oct 8, 2008 | 02:21 PM
Max_5gen's Avatar
Oh, you haven't been around long enough then - people get all kind of things like inhibitor switch, relay, bad contacts. Bad starter is the most common one though. Your tapping must be very hard too .
halfpol
Oct 17, 2022 12:16 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
