rattling noise in front pass side
Old Oct 6, 2008 | 05:15 PM
rosader's Avatar
This noise gets pretty loud over bumps. I'm thinking its either a bad strut, ball joint, or cv axle. what is the best way to figure out which one is bad?
Old Oct 7, 2008 | 09:41 AM
rosader's Avatar
anybody?
Old Oct 7, 2008 | 11:07 AM
njmaxseltd's Avatar
STEP ONE:
Jack up car
STEP TWO:
Inspect ball joints
Inspect Axle
Inspect strut and spring assy
Inspect the control arm bushings
Inspect the sway bar end links
Old Oct 7, 2008 | 12:59 PM
MerryMaxa2's Avatar
Also check motor mounts. I had a similar sounds and after the original dealership replaced almost everything in my front end....when to another dealership and service tech correctly diagnosis problem.
Old Oct 8, 2008 | 01:23 PM
Crasher's Avatar
nice njmax lol
Old Oct 11, 2008 | 03:03 PM
rosader's Avatar
Originally Posted by njmaxseltd
STEP ONE:
Jack up car
STEP TWO:
Inspect ball joints
Inspect Axle
ok i checked all of the above and i narrowed it down to the strut
should i replace both struts or just the one? I checked napa and the told me $226 each
is that typical to be that pricy?
Old Oct 11, 2008 | 04:24 PM
SoulEater's Avatar
What? $226 for EACH? that's so damn expensive. just get tokico illuminas. i got mine $420 shipped for 1 set (2 front and 2 rear)
Old Oct 11, 2008 | 04:48 PM
oc_wicked's Avatar
I would really recheck your sway bar end links usually that what makes the sound when going over bumps. my car was rattling even on the smallest bumps changed the end links and now very quiet over bumps. just a thought b4 you put all that money into struts!!!!
Old Oct 12, 2008 | 09:43 PM
nexus_7's Avatar
inner tie rod is what makes that noise for me...just about to replace it.
Greg
Old Oct 16, 2008 | 08:00 PM
03blackSE's Avatar
I have a similar noise coming from the driver's side. A little vibration going over the smallest bumps.
Newbie question coming up:
After jacking the car up, is it visually evident that the tie rods or end links are on their way out?
Old Oct 16, 2008 | 09:43 PM
nexus_7's Avatar
move them around...if they are loose feeling it needs to be replaced.
Hondarydr
Dec 30, 2024 06:15 PM
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
follyburr
Aug 7, 2015 09:50 PM
