Toruq spec for brake line to caliper?
Old Oct 16, 2008 | 06:03 AM
n3985's Avatar
大陆弟弟
Planning to DIY my 6th gen caliper upgrade this weekend and was wondering how tight I am suppose to tighten the nut on the brake line to the caliper? (keeping factory lines for now)
Pretty much just loosen the nut, take off old caliper, install new caliper, re-install line and bleed the system right? and 10mm flare nut wrench is recommended? Thanks
Edit: Forgot that I can't torque down that nut since I'm using a wrench so is it just hand tight then?
Old Oct 16, 2008 | 08:26 AM
kdarcangelis870's Avatar
According to the fsm its 11-13 ft lbs of torque, but i don't know how you could get a socket on there. Hand tight plus a quarter turn should do. You don't want to overtighten brake fittings, i have learned that the hard way many times.
Old Oct 16, 2008 | 08:30 AM
n3985's Avatar
大陆弟弟
OK thanks, from what I've read there should be 2 copper washers when I take off the caliper fitting, it's OK to re-use or no? (keeping the factory line, swapping calipers)
Old Oct 16, 2008 | 10:36 AM
ZIPPIN's Avatar
Mauja He Mauja
I have reused them as long as they arent rusty or bent...
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Dec 12, 2015 09:39 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Johnny9595
Sep 16, 2015 07:20 PM
