6 Speed tranny ???
Old Oct 16, 2008 | 07:31 AM
jd885's Avatar
6 Speed tranny ???
Hey you guys... I've got a quick question... I have an 02 6-Speed (of course) and every once in a great while when i have been on the highway for a while... i get off the ramp like everybody has to and the car will not go back into the slot where 1st and 2nd gear sit... i mean i am in neutral and i can only access 3rd, 4th, 5th, 6th... then i have to fiddle with the shifter till i can force the little bastard left in neutral so i can get back to 1st and 2nd... then its fine for a while.... THANKS GUYS
Old Oct 16, 2008 | 08:26 AM
pbn85's Avatar
Im assuming your speed is too high getting off the highway to be getting into 2nd and ESPECIALLY 1st. Have you ever tried getting into first going 10mph? It wont happen.
Dont force the car into gear when it doesnt feel like. You will ruin your tranny
Old Oct 16, 2008 | 08:28 AM
AEMAXIMA01's Avatar
How many miles are on it? How fast are you traveling when you try to put it into 1st or 2nd?
Old Oct 16, 2008 | 08:35 AM
jd885's Avatar
no sorry for not making it clear guys... i know how to drive a stick ive been driving one for 5 years (i never put it in 1st unless im damn near stopped)... i mean i stop (completely) at the end of the off ramp and the stick wont go left in neutral to the space where i can throw it up into 1st or down into second
Old Oct 16, 2008 | 09:01 AM
bladerunr's Avatar
sounds like a typical bad synchro. when was the last time you changed your tranny fluid?
Old Oct 16, 2008 | 10:27 AM
LA02MAX's Avatar
It's not a synchro, read the post again. He can't move the shifter to the left in the neutral position...
Check the shifter cables to see if they're binding on anything as well as the shifter linkage on the transmission (remove the airbox to access this)
And FYI you can get your car into first at any RPM as long as you rev match. (double clutch..)
Old Oct 16, 2008 | 12:15 PM
jd885's Avatar
ok ima check the linkage ... havent had time to do it today cuz the lifts have been tied up but i did take the interior off and grease all the linkage parts in there.... next is greasing the outside linkage on the tranny...LA02max that was exactly what i think it is but figured i would ask you guys ... oh and of course it freed itself up like it always does after i screw with it for a min so ima grease everything and hope for the best
Old Oct 16, 2008 | 01:26 PM
knight_yyz's Avatar
Toolie
my guess is the hitch pin may be broken where the shift rod and linkage meet
Old Oct 16, 2008 | 01:54 PM
LA02MAX's Avatar
I've seen it happen several times. Could be hangin on for dear life.
Old Oct 17, 2008 | 02:25 AM
knight_yyz's Avatar
Toolie
Happened to me too. Took me a while to figure out why I couldn't shift either.
Old Oct 26, 2008 | 06:54 PM
ynot411's Avatar
I'm in this predicament now since I missed 3rd gear at the track on Friday. Accidentally, went into 1st and it was all down hill from there. It is extremely hard to get it into 2nd and reverse and cannot get it into 1st at all. Not sure what I broke or damaged yet.
knight_yyz
Nov 1, 2015 01:34 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
uttadms31
Sep 30, 2015 05:24 AM
