Are Z32 brakes = R32 brakes?
Old Oct 27, 2008 | 06:33 AM
SoulEater's Avatar
Did some research, but couldn't find the answer. Is anybody know that R32 brakes are the same as Z32 brakes?
Old Oct 27, 2008 | 06:41 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/tires-wheel...eal-quick.html
Old Oct 27, 2008 | 06:45 AM
SoulEater's Avatar
I know, but nobody mention if they are exactly the same. I just curious if the bracket from Matblem will fit on R32? also i need to know which rotor i can use with R32 caliper.
Old Oct 27, 2008 | 06:47 AM
Greeny's Avatar
¯\(°_o)/¯
Post #5 ?
Old Oct 27, 2008 | 07:05 AM
SoulEater's Avatar
aight, u r right. but does he mention if the caliper will fit with 6/cobra rotor, and the bracket as well?
Old Oct 27, 2008 | 07:23 AM
Matt93SE's Avatar
STFU n00b!
I can't say for sure if the bracket will fit or not. Based on my experience with the R32 GT-R rotors on my 3 gen and my S14, I'd say they won't fit.
BUT.
Also keep in mind the R32 has at least 3 different brake options.
R32 GTST has sliding 2-piston calipers (like the us-spec Z31)
R32 GT-R has 4 piston calipers, just slightly larger than US spec Z32.
11.75" x 1.25" rotor as opposed to the Z32 11" x 1.1" rotor.
R32 GT-R V-Spec has Brembo 4 piston calipers.
http://www.dba.com.au/2006/PDF_CATAL...s_02032008.pdf
Old Oct 27, 2008 | 11:34 AM
SoulEater's Avatar
BUT.
Thanks a lot for the info. I think i have to stick with the Z32 brakes
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
