body parts
body parts
My roommate just backed into the Max today. I'm trying to source parts and figure out what all I'd need to get this fixed fast. To me, it looks like it needs a new headlight, foglight, bumper cover, foam support behind cover and POSSIBLY a new hood. It appears to have a slight bend in it, but it may just look that way because of other damage.
Do you have any recommendations on where to source 2001 AE Parts? I'm tryin to help him, but we may have to get insurance to pay this. Thanks for any help.
AE parts are hard to come by and expensive. The front lip doesn't seem to be damaged so you could probably remove it and have it installed on the new bumper. All other parts should be available.
Hoods can be purchased for around $175 shipped, bumper around $150, headlight about the same if you look on fleabay. Paint should be about $250; all in all, it's going to run at least $700 to $1000, PLUS the time you spend for removal/reinstall.
The hood looks to be ok, it appears as though it's only being propped up by the grille. No hood should put you well below $700.
Ii found a headlight assembly on ebay for 110. Is that just a standard bumper with the AE lip attached? If so, I could get any 01 max bumper and have it painted to match? Does the foam backing come with the new bumper? Do you have a link to the hood for 175 and bumper for 150? Also are the AE foglights also special edition? Thanks
Hood - $280 shipped
Bumper - $130 shipped
Fogs, $68 shipped (just as much for one, will look stupid if only one's replaced)
GL, man.
I would get his insurance to fix it if you want it done right and you would get a rental so youre not out of a car.
If not get a bumper,any 2000 2001 will do, try to put it on and then see what else needs to be replaced after you try to line things up.
Parts bodywork and paint arent cheap.
Yeah... were running it through insurance. Got a quote from maaco to do it all including cracked grill molding, and mounting tabs etc. $2350. Im having Allstates body shop, Sterling Autobody do the work. They'll start monday, and I'm gettin a Gran Prix rental on Friday, that will be fun.
Should I specify that they put in an AE headlight, or just let them do that one with a regular light, cause I'm going to buy a passenger side light and put it on myself when it's done, so the headlights will match.
Damn..... your room mate must have wacked it good! They probably wont give you 2 AE lights. My buddy had something similar happen and they would only replace the light that was damaged but.....They sell this stuff at autozone and it comes in like some shiney bag and its great for restoring head lights. You should find it in the light section or just ask someone. It should help the old light match the new light. I used it on my 99 and my 02 (eyelid removal lots of gunk stuck) and if you do it right it'll make them look like new.
Hi
Sorry for the wrong place, but I can't create new thread.
Follow is my problem:
I need to get Rear Planetary Carrier (those thing with four little gear wheels) but can't find it. Can anybody advice where i can buy online? Searched whole internet but still no reaults
Also is it good place to buy clutch plates on http://www.transmissionpartsusa.com ?
My tranny is RE4F04A. My car will not run w/o those rear planet part
