Noise is uppder strut mounts, help!
Old Nov 13, 2008 | 10:58 AM
2KmaximaSE's Avatar
Took the max into the local shop today and they are telling me the noise I am hearing when I turn my steering wheel is my upper strut mounts. It's a low pitched kinda sound which you would expect with a belt loose or something.
He said the mounts are weak and it's the same labor to replace the struts (which he said are weak too) at the same time as the mounts but said it's just the noise so I don't have to get it done right away. The noise is annoying when I am turning, it's always there. Could this be the truth?
He quoted me $800+ to replace the struts and the mounts in the front.
That seemed really high to me, has this happened to anyone else and what did you guys do about it?
Old Nov 13, 2008 | 12:03 PM
Torgus's Avatar
rip off.
Old Nov 13, 2008 | 12:30 PM
OOmaxSE's Avatar
I'm guessin your suspension is stock. Jack your car up and spray some lube/greece around the spring. Chances are, it could be the springs binding with the strut and squeaking when you're turning... you'll see. Give that a shot and report back.
Old Nov 13, 2008 | 02:27 PM
ghostrider17's Avatar
THe diagnosis sounds right, but the cost he's charging is outrageous.
Although - I'm sure he's quoting you their basic shop rate of $90 per hour or more....which would actually calculate correctly, believe it or not.
You DO indeed have to remove the entire strut assembly, spring, etc. to replace those parts.
So, in actuality -- he's being honest.
It's just that his labor rates are insane for such basic services.
I'm suffering the same prob. with mine right now, and it's driving me NUTS!!!
I don't have access to proper equipment rt. now to fix it myself (done it before) but I'm just going to wait and deal with the noise for now, as annoying as it is -- it's not hurting anything on my car.
good luck.
gr
Old Nov 13, 2008 | 04:15 PM
boondoxmax's Avatar
Is the noise when turning bad mounts. What about clanking noise on irregular road surfaces, can that also be strut mounts as well.....
Old Nov 13, 2008 | 04:34 PM
2KmaximaSE's Avatar
I talked to the guy who worked on my car and he said that it just stayed where they put it. Pull the car up and it stayed there, pushed it down and it stayed there. I am guessing he is talking about my struts but said I could drive on it if I could deal with the noise, I guess I will keep doing that for awhile.
Could this be the springs binding with the struts like OOmaxSE said and simple lube/grease on the springs would fix this problem?
Old Nov 14, 2008 | 06:08 AM
No. Springs don't "bind" -- doesn't work that way.
Turning noises indicate bad strut bearing (mounts on top of assembly) and clunking while driving (my problem) is caused by worn-out seats / rubber components on the hat.
Either way - you have to pull the whole assembly from the vehicle and remove the spring -- which is where the work lies.
Oh - and your car "not moving" means your struts are bad.
gr
Old Nov 14, 2008 | 06:24 AM
FlipCpt45's Avatar
gr
Hmm, I'm having the same problem with only one side.. and its FKN loud esp when im going down my driveway in reverse... Do i have to get OEM? or could i just go to Advance auto parts / Oreilly's to get them?
Old Nov 14, 2008 | 07:49 AM
quiksilver20004's Avatar
This is an easy fix guys you are making it out to be a lot harder than it really is and that shop guy that s a crazy price i could do this job in under an hour hell i put lowering springs on my car all 4 wheels in 45 min.
Get on ebay or go to a autoparts store and buy an upper strut mount or for those of you that need struts then buy them too and if your doing struts then replace both at the same time!! With parts in hand go to autozone or somewhere that rents tools and rent spring compressors. Now pull the tire then release the strut from the hub by removing two bolts. the two bolts have and 18mm side and a 16mm side i believe not sure on the 16mm maybe a 17mm but anyways once you have done that go into the engine bay and take off the 3 nuts on top of your strut mount (15mm i believe) and the entire assembly should slide out. Now the tricky part is getting the springs and struts apart. put the spring compressors on the springs and compress them moving back and forth as to not **** the springs (easiest with an impact) Now the fun part you have to keep the strut from turning while removing the strut nut on top. Some struts you can use a combination of two wrenches and work them opposite ways to get the nut off. In worst case scenario if you are trashing the struts you can cut the nut off the top. For those of your replacing the upper strut mount once you get the nut off pull the old mount off and put the new one on. Now reassemble in the opposite order.
Seems like a lot of work on here but its really not guys its very easy unless your one of those severly mechanically challenged types.
Any questions let me know.
Old Nov 14, 2008 | 11:03 AM
2KmaximaSE's Avatar
Thanks to everyone for their help, last question on this subject...
Since I have to get new struts are there after market ones I should get instead of OEM that will last longer or that work better? The lower the price the better for me as well. As for the strut mounts, where is a place to get them at a good price and if anyone has part/model numbers that would be appreciated as well.
Thanks again for the help on this!!
Old Nov 14, 2008 | 11:10 AM
Well i have one upper strut mount for sale on E-BAY if you wanna go on there. But other than that either call around or search the net. Recommended struts are KYB GR2's many people have run them and absolutely loved them said they made a huge difference.
Heres my listing on ebay just to give you an idea and makes sure its what your looking for.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old Nov 14, 2008 | 11:22 AM
Lots of variables to your question, but here's my 2c:
I've had Tokico Illuminas, and I think these are truly the best option for our vehicles aside from getting Coilover units.
Illuminas will pair with ANY OEM or aftermarket spring combo, with NO issues of premature wear.
However - i've not tried the Tok Blues, or the KYB Gr2's.
If you are buying NEW, I'd say go with either of those three, depending on how you drive, the mileage on your car, and what springs/tires you run.
WIth that being said: if you are looking to stay stock (springs) I'd say try and find some low mileage USED OEM struts, and go with those. Don't waste your money on NEW OEM Struts, for the same $$$ you can buy top-rated Illuminas.
However: I would NOT recommend buying USED Top-Hat Assemblies. Then, you're just right back in the same boat that we are ALL in....and that's suffering the consequences of worn-out rubber and bearings. These are like $50 per corner, and spending the $$$ now, is better than having to disassemble the whole thing AGAIN in a few thousand miles, and replacing it ALL over again.
good luck.
gr
Old Nov 14, 2008 | 11:29 AM
For sure go with one of those three. I wouldnt recomend used struts or any used parts cause you run the risk of getting the ones off of someone who absolutely abuses their car.
I hate to see a Maxima abused but it does happen
Old Nov 14, 2008 | 12:02 PM
I agree - you have to be careful when buying used ( i wouldn't) but there ARE alot of reputable members who have ditched their low-mileage OEM's for aftermarket, who are selling for cheap.
Agreed though -- better-off going with newer aftermarkets.
Just be CERTAIN you do your research with spring/strut combo's if you are going with ANTHING BUT Illuminas.
gr
**I think it is GENERALLY accepted that the H&R Spring / illumina combo is just about the best compormise on ride, handling, and drop**
Old Nov 15, 2008 | 08:33 PM
2KmaximaSE's Avatar
Do I need the strut bearing when I order the strut mounts?
I am finding that they are sold seperatly. Do I have one on my old mounts or do I need to buy a new one for each side along with the mounts? Here is the website that I was looking at: http://www.mypartscatalog.com/parts/...rut_mount.html
They also had KYB struts there for $100, is this the kind you were talking about... http://www.mypartscatalog.com/parts/..._assembly.html
Old Nov 17, 2008 | 10:18 AM
I would buy the mounts with the bearing just to be safe. I mean you will already have it all apart so why not replace a couple dollar part while your at it. Plus from the site it says that the KYB mount with the bearing is cheaper.
And yes those struts are the KYB GR-2's They are great struts but do your research and check around you may find them cheaper or another good brand for less.
Check this site they have a lot of stuff
http://www.sportcompactonly.com/default.htm
Old Nov 17, 2008 | 03:08 PM
Torgus's Avatar
#1 it's easy enough to do in your garage on a saturday.
#2 it isn't to expensive to do them all at once and aftermarket is always an option
#3 i say buy some nice coilovers...
g'luck!
Old Nov 17, 2008 | 03:15 PM
nissan maxima's Avatar
if i was u i wont spend the money on stock suspesion i will get some tein suspension or H,R for that price and to install them u could do it u self is not hard all u need is a 14 sacket 17,3/4 and a jack tha's it
Old Nov 19, 2008 | 06:37 PM
Old Nov 20, 2008 | 06:46 PM
petemo95se's Avatar
I've had Tokico Blues (non-adjustable) before and hated them on my 95 SE. No rebound control, car hopped too much. Then tried KYB AGX's and loved them and it's variability.
For the extra money, GET THE ADJUSTABLE struts. You will NOT be disappointed. Planning on getting Illuminas for my 02 SE.
Old Nov 22, 2008 | 04:09 PM
kbohip's Avatar
Would worn strut mounts cause the car to bottom out easier, say on a road that has a slight dip in it? My '02 does this in the same spot every day on the way to work. My wife's '91 Max otoh never has a problem with this spot at the same speed.
I'm also getting a slight clunking when pulling into my driveway. I'm assuming the strut mounts have to be the culprit, but I've never had to replace them on any of my cars before so I'm wondering. My front strut boots are torn anyway so regardless I'll have to take my struts out to replace those. That's what I get for not replacing them when I put my Illumina's on 10k miles ago.
Old Nov 23, 2008 | 11:02 AM
From your description it sounds like you have a bad strut not the mount. or when you put the illuminas did they have bump stops on them or not??
Old Feb 11, 2009 | 06:35 PM
Burny's Avatar
where can i get a spring compressor to do this job?
Old Feb 12, 2009 | 06:59 AM
MidN1te's Avatar
Just go to advanced auto parts.. or some place like that.. they rent the tools... essentially, your purchasing the compressors for like 58 bucks... if you dont return them, you just spent 58 bucks.. if you did, you got your money back.
for those that have trouble taking off the top nut with a 17mm socket AFTER the whole spring is out as the unit.. do this FIRST..
Loosen the 17mm Nut FIRST a couple of turns... that way you can take off the nut without having to try to hold the mount at the same time,
then loosen the 3 nuts on top with the 14mm sockets just a couple of turns.
then after you remove the brake lines out the way and loosen the big nuts at the bottom with either 3/4 or 19 mm, then your good to go.
I'm having problems again right after i changed the strut bearings... only on the passenger side.. so i just ordered a new mount with the bearing.. hopefully that does the trick.
Old Feb 12, 2009 | 07:18 AM
CMax03's Avatar
If the noise is coming from the right front side of the car....more than likely it's your motor mount located on the right fender...please break out the pry bar to work the mount up and down and you'll hear that clunking noise!
Old Feb 12, 2009 | 09:31 AM
MidN1te's Avatar
^ hahah your REALLY fixed on that motor mount huh...
Old Feb 12, 2009 | 09:38 AM
CMax03's Avatar
That I am! The right side noise that appears during suspension oscillation is always first thought to be the actually suspension components due to it's occur during driving and associated with bumps, turning and the like...This particular motor mount failure is always overlooked as a suspension problem...with it's actually the motor contacting the frame close by the strut and it really does sound like a defective /blown strut or worn strut mount!
Old Feb 12, 2009 | 12:05 PM
djfrestyl's Avatar
Suspension Yoda
You're out in PA. I can do the suspension install for you if you'd like. My price is much better than any quote you'd get elsewhere. Let me know...
Old Feb 15, 2009 | 03:52 PM
MR KING's Avatar
I'm getting a squeeling noise coming from the drivers front only during deceleration, it isn't the brakes (just replaced pads)? Any ideas? It is a stock 2002 maxima w/ 90k miles. Thanks
Old Feb 15, 2009 | 07:19 PM
hi-tek22's Avatar
wait, what are you thread hijacking?
Now are u sure it isnt the brakes. Do you hear the noise when you take your foot off the gas?
post that in the N00b thread
http://forums.maxima.org/5th-generat...on-thread.html
Old Feb 19, 2009 | 09:47 AM
CVicVogel's Avatar
KYB Strut Mounts
When I bought my KYB Gr-2's, I also bought the KYB strut mounts. Both were high quality and worth it in that with the better shock, it is does not have to work with a partially worn stock mount. BTW...I did give my OEM mounts away for free and frankly, they did have some life left in them.
Always buy new mounts when buying new struts...IMHO.
Vic
Old May 12, 2010 | 09:19 PM
m.xie's Avatar
I also have the problem, but with upper strut bearings, not mounts.
I know nothing about this before. They ask for about 400 to replace it. Is the price reasonable?
Old May 13, 2010 | 05:14 AM
djfrestyl's Avatar
Suspension Yoda
That's a lot just for bearings. Where are you located?
Old May 13, 2010 | 04:05 PM
1800bucks's Avatar
I'd say thats too much money. I just bought new strut mounts and had the Tokicos put into my new/used H&R's. The MOOG brand was $55 per side, and the strut swap was $64 after tax. That's less than half of what you were quoted.
If you need a set of strut mount and bearings, I have a set of OEM's. I had a clunking from the front and thought it was the strut mounts and bearings. After replacing struts, springs, TRE's and SM kit, I still have the same clunk. Went and got a 4 wheel alighnment Monday after work and found the issue was the passengers side sway bar end link bushings. The strut mounts and bearings I had removed are in perfect condition, they have a coating of lithium grease on them. If you need a set cheap, LMK.
Old May 14, 2010 | 06:24 AM
djfrestyl's Avatar
Suspension Yoda
Yea I've got a set of mounts sitting around too. I was asking where m.xie was located because I do suspension installs for org members.
matts95max
Apr 23, 2025 10:44 AM
Andy29
Sep 29, 2015 05:32 AM
lrb6805
Sep 17, 2015 04:49 PM
Bonka
Sep 14, 2015 11:18 PM
