Anybody ever try the OEM fog lights off eBay?
Old Nov 24, 2008 | 12:48 PM
XGaSpAcHo's Avatar
my right fog light is shattered and i need to buy a new one. the local dealership quotes me over $200 for one. i found this one on ebay for about $75
http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
wanted to know if anyone had tried them and if they were any good or complete garbage. i still need to call dave b. and see how much i can get it from him for.
Old Nov 24, 2008 | 01:55 PM
phatboislim's Avatar
I'D SELL U MY OEM ONES...
Old Nov 24, 2008 | 01:57 PM
XGaSpAcHo's Avatar
is there a but right after that?
Old Nov 24, 2008 | 01:59 PM
jeff5347's Avatar
i replaced mine about a year ago due to being cracked n the hiway. I replace both as one looked real nice and new and the orig, well you could tell was not knew. Im happy with mine. Has fit perfectly with no problems. Only thing i did which was more work was go to home depot and got some 1/8 inch plexi and cut it to the shape of the glass and them siliconed it to the face. I let it sit about 2 days then put it back on the car. No more cracking or anything. If you do do it make sure you have it siliconed good or you will get water between the glass and plexi.
http://cgi.ebay.com/ebaymotors/_Car-...4506.m20.l1116
Old Nov 24, 2008 | 02:11 PM
XGaSpAcHo's Avatar
did the plug fit right in without you having to do any kind of wire splicing?
and do you have any pics of what they look like?
Old Nov 24, 2008 | 03:56 PM
VQP0WER's Avatar
$147 through Courtesy Nissan
http://www.courtesyparts.com/26156-l...1957_1996_2006&
Old Nov 24, 2008 | 07:19 PM
DoubleOmax's Avatar
i bought the fogs off ebay, the plug was different though, so i had to cut it off my old foglamp and splice it. works perfectly fine.
Old Nov 24, 2008 | 07:28 PM
Deckdout2's Avatar
Play with my balls
Get the ebay ones, they will crack again. I've replaced both of mine about a year ago, and the passenger side was cracked about 2 months ago, maybe longer. I just noticed the driver's side one this past weekend. I will be replacing them again with the ebay ones. A little under 100 bucks for both, and for something that will need replacing. Unless you go the plexiglass route which might not be a bad idea if it does not disturb the light output and pattern. btw, I have 50 HID fogs.
-p
Old Nov 24, 2008 | 08:16 PM
CMax03's Avatar
Yeah an Orger bought some of those cheap a$$ crap to my house to put the protective film on ...the height adjustment screw is a hard to find phillips screw instead of the hex head bolt found on the Oem fogs. The lense is thinner than the Oem cause the SOB cracked from the bulb heat...not a FOD strike! Buy the foglight kit from Courtesy Nissan or ABC Nissan it's less expensive as a kit than individual foglights and it's the real thing!!!!!
Old Nov 24, 2008 | 08:28 PM
lol no, just let me know ur price, the PM'd price is not firm, its just off the top of my head i dnot know what they go for or what u wana spend
Old Nov 24, 2008 | 11:17 PM
navigator82's Avatar
i have mine from ebay like a year ago an still very good i drive like 14 miles every day an ihave no cracks or anything good price an good quality i dont remember the price but i know where to buy the fogs autopartsavenue in ebay
Old Nov 25, 2008 | 03:22 AM
4thgenmaxboy's Avatar
I bought one from this seller "edixworks" off of ebay about 2 months ago. The fit and finish were excellent, and it was plug and play. I paid $52 shipped, and 2 months later all is well still! Forget that $150 one from the dealer.
Old Nov 25, 2008 | 03:24 AM
Professor's Avatar
I just bought a OEM PAIR off ebay for $24 ^________^ my max never had them, its prewired, i already got the new turnsignal/fog/headlight switch and relay, just waiting on my fogs to come in the mail. pics when i get them
Old Nov 25, 2008 | 05:32 AM
jeff5347's Avatar
yea the plug had to be cut off and the oem one soldered on. Not a hard job at all. The only hard part about the plexi is making sure you dont crack it while working on it. I had put duc tape on it so it was less prone to crack and i cut it with a hack saw and them used a grinding wheel to finish the oval and smooth the rough spots. There will be some residue left when you take off the tape but rubbing alchohol will remove it. Then silicone it to the housing and let it be for 2 days so the silicone can fully dry.
Also the light was not disturbed. I was thinknig that to so i did one at a time. When i had them in the car with one plexi'd and the other not i couldnt tell a difference. I love mine and im sure they have saved the glass from cracking lots of times. I live near new road contruction and they look like new,.,
Old Nov 25, 2008 | 05:38 AM
CustomLowz's Avatar
I bought a set from ebay, while the car was stuck in the garage for a few days (new driveway). I installed the lenses, turned the lights on to admire, and forgot they were on. 15 min later, i notice them, turn them off, and both lenses were shattered.
Old Nov 25, 2008 | 02:12 PM
CMax03's Avatar
We'll see if you can make 5 years. My Original fogs were cracked 3 months after I bought the car brand new(Flying Debris). Paid about $117 from ABC Nissan for the entire foglight kit which is less expensive than buying the foglight by themselves, applied the protective lense film and they're freakin bullet proof now, and beaming down the road with 8000K HiD.....Mark your calendar, cause cause you'll get what you pay for every single time! I'm going on 6yrs real soon.....
Old Nov 25, 2008 | 09:00 PM
hi-tek22's Avatar
are the fogs on ebay PLAIN DEPO LIGHTS? OR ARE THEY OF POORER QUALITY?
Old Nov 26, 2008 | 02:57 AM
Professor's Avatar
Depends, i know the ones i bought came off a 2000 maxima
Old Nov 26, 2008 | 04:11 AM
ptviperz's Avatar
My ebay fogs are Denso I think. Been fine for a year.
Old Nov 26, 2008 | 05:10 AM
vball_max's Avatar
Did you ever do a how to write up on the plexi glass? It sounds like a great idea, but it sounds kind of messy and that it may not look so good afterwards.
Also, while this thread is active, my fogs have cracked several times. Even after I put lamin-x films on them, the driver side cracked within a couple months so i am thinking its more heat related than from road debris. I am thinking about getting HID's for my fogs so my question is do HID's typically produce more or less heat than halogen bulbs? If I went from the 55w halogen to a 35w HID, could that possibly solve my problem if its heat related?
Old Nov 26, 2008 | 06:39 AM
jeff5347's Avatar
you know i never did a write up and i should have given these fogs break all the time. I can take a pic today and show you what it looks like. It is un-noticeable until your right on top of it and then it still does not look bad. It can be messy if your not patient thats why doing something like this is not to be rushed. Ill get pics of the fog later today and post up by noon. I did notice that if you lay the stock fogs on a table they sit nice and flat. The ones i bought off ebay are depos and they have a slight curve to them. Makes it a little more pita to do the plexi but not impossible, which is why much patience is needed.
i believe the hids produce less heat. I switched my fogs to 6000k hid h3 bulbs. When i say brighter its like night in the middle of the woods with no moon out to staring at the sun on a nice summer day. Mine light up the road greatly.
Old Nov 26, 2008 | 07:19 AM
jeff5347's Avatar
ok did a quick how to for my cardomain page on how to do the plexi for the fogs
http://www.cardomain.com/ride/2547814/8
Old Nov 26, 2008 | 05:53 PM
arimaincorp's Avatar
i bought a replacement from eBay it lasted for about six months and cracked again. I bought another one from eBay and its been going for about 2years. I think the brand was depo or something like that. It was an exact fit, same wiring and all. you can get it cheaper then the seventy something dollars. i paid $55 shipping included.
Old Nov 26, 2008 | 06:23 PM
Double0Max's Avatar
yea no problem when i bought mine a few years ago at the time they really didnt have a selection of maxima fogs so i bought the 2001 fronteir fogs instead turned out to be the same fogs..lol
Old Nov 27, 2008 | 01:25 AM
MIK3's Avatar
I was actually thinking about these:
http://www.andysautosport.com/nissan...d00135394.html
Old Nov 28, 2008 | 02:13 PM
Professor's Avatar
Well, I got my OEM fogs from ebay today for $24, here is a small video of them, They dont match the HID headlights yet, but sooooooooooon they will.
http://www.youtube.com/watch?v=5Od7G0V4bws
Old Nov 28, 2008 | 02:20 PM
Those look hot.
Originally Posted by Professor
They look good. Throw some HIDS in them and you'll be set.
Old Nov 28, 2008 | 02:22 PM
Professor's Avatar
cant wait for hids, shopping now
Old Nov 28, 2008 | 02:27 PM
tbaGd_jEw's Avatar
I've bought the ebay ones before, and they were fine. Just beware of anything under 99% or anything..."to good to be true."
Whatever you have in the headlights, get that in the fogs too.
Old Nov 28, 2008 | 02:30 PM
Professor's Avatar
Yeah there 6000K , the fogs are authentic oem, they say nissan right on them.
Old Nov 28, 2008 | 02:38 PM
Nice job gtting OEM, it's the way to go. But yeah get 6k in the fogs as well.
Old Nov 28, 2008 | 03:51 PM
Professor's Avatar
I added another Vid, check New Vid thread under member rides.
Old Dec 7, 2008 | 06:43 PM
Stereodude's Avatar
Originally Posted by VQP0WER
I assume from looking at the drawing on their site that this is the "cheaper" OEM kit people are mentioning in this thread?
Old Dec 9, 2008 | 01:37 PM
NisTech's Avatar
mine was called depo smething too. perfect fit and even aimed right
Old Dec 9, 2008 | 06:37 PM
Professor's Avatar
Them little nipples in the bumper cover that the pins in the fog lights set it, where can i get those, iam not having any luck at junk yards and a dealer is really far away.
Old Dec 9, 2008 | 07:10 PM
Monkeyknowitall's Avatar
Quick Question i'm actually new to the forums but i'd like to know, I don't know if anyone knows but i wanna be able to use the factory foglight switch but turn on the foglights without the headlight being on???...is there a way and if so does anyone know???
Old Dec 9, 2008 | 07:30 PM
Stereodude's Avatar
That depends on the year of your Maxima, but this site would probably be a good place to start looking.
Old Dec 26, 2008 | 01:22 PM
02PatMax's Avatar
first post here, the right foglight on both mine and my moms 02 maximas are out. her light is cracked, mine is not. I'm wondering if i need to replace the whole foglight on my moms car and where i can get an OEM bulb for mine that burnt out?
Old Dec 29, 2008 | 11:46 AM
bigsherv's Avatar
you can replace the bulb only
