what wheel stud do i need
Old Dec 1, 2008 | 08:24 PM
jeff5347's Avatar
ok so im going to add 15 mm spacers on the rear. I found some ichiba studs at option auto but not sure which ones to get
http://www.optionsauto.com/products.asp?dept=7227
so do i need the ones that are 14mm knurl or the 13mm knurl, remember these will be going on the rear. Also the im looking at the 50mm studs. Can i use 10-15mm spacers with these. Meaning using the stock lugnuts say with a 10mm spacer will it screw right to the wheel and tighten it or will it bottom out before it hits the wheel. they say 50mm is just the length of the treaded part. What is the threaded length of our stock lugs, 42 mm or is the the total length of the stud
Old Dec 2, 2008 | 01:00 AM
CMax03's Avatar
get the real McCoys from Nismo...You can order thru Courtesy Nissan Richardson, Tx (near Dallas)...you'll never have a problem wtih these...
Old Dec 2, 2008 | 04:25 AM
jeff5347's Avatar
i dont think ill have a problem with ichiba either. Which one though do i need. Either way isnt the rear different for m the from in knurl size. im not sure what i need
Old Dec 2, 2008 | 04:40 AM
AceofSpds's Avatar
wat
Most nismo parts are NOT worth what you pay. For that price you can get ARP wheel studs.
Front and rear knurl sizes are the same IIRC
Hell they better be, i bought 4 or 5 at the same time and used both on the rears and the fronts. I haven't had any issues.
Old Dec 2, 2008 | 05:42 AM
jeff5347's Avatar
i agree alot of stuff for vehicles is way overpriced. insane how people will buy stuff that is marrked up 400 % ok cool . im gonna order the ichibas and see what happens
Old Dec 3, 2008 | 07:31 AM
mowgli29's Avatar
Horizontally opposed.
ok so wait... we need the 14mm knurl, right? And I made some ~8mm spacers out of old rotors....so I was thinking I'd go with the 45mm length...but I have open ended lug nuts so 50mm should be fine too, right?
I'm a 4th gen...but I would assume it's the same. Can anyone prove otherwise?
Old Dec 3, 2008 | 07:36 AM
CMax03's Avatar
Nismo maybe overpriced but they can take that continuous beating even while you're sleeping....
Old Dec 3, 2008 | 07:49 AM
jeff5347's Avatar
yea if you have an open ended nut you can use any length.
i was curious because i am using the acornm style and dont want to bottom out the lug before it secures the rim to the hub
Old Dec 3, 2008 | 08:16 AM
mowgli29's Avatar
I don't doubt that, but I think ichibas will be plenty strong for me. Not to mention, the whole reason I made 8mm spacers from old rotors was to save money....so it would be silly to spend an ungodly amount of money on nismo studs that are stronger than I need. I've never broken a stud in my life, and I wouldn't think Ichibas are weaker than OEM....so I think I'll be ok. I hope....
Yeah that's tough....luckily ( I guess you could say) I had to get tuner lugs when i got my new wheels, so I just went with open ended just in case...now I'm glad I did!
I think if you stick within the ranges specified on that site, you should be fine. There is a decent amount of room left in the stock nuts with stock studs....so try to lengthen the studs the same amount as the spacers' thickness and you should be fine. Does anyone know the OEM stud length though?
Old Dec 3, 2008 | 08:31 AM
jeff5347's Avatar
i called ichi ause i wanted to know as well. The said the thread length is 30mm. I looked on advanced auto parts and they list the total length as 42mm
Old Dec 3, 2008 | 09:27 AM
mowgli29's Avatar
oh ok. yeah, 30mm + 15mm spacer would be a 45mm stud....so that sounds right to me! thanks for the info!
Old Dec 3, 2008 | 10:40 AM
AceofSpds's Avatar
wat
you could try going into a parts store that isnt busy or has good customer service and ask a guy to pull a stud so you can measure it.
Old Dec 3, 2008 | 10:43 AM
Deckdout2's Avatar
Play with my balls
You need the 14.xx mm knurl. trust me on this.
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
