Overlays trouble
Old Dec 7, 2008 | 06:01 AM
croser2's Avatar
Overlays trouble
Has anyone put on some Bluebatmobile taillight overlays on their 5th gen. I tried, but to no avail. The curves were just too hard. Just wondering if anyone had some good advice.
I got a solid sheet of red and cut out the reverses, but the install looks crap so I'm gonna take them off, I just snapped some pics while they were on.
I guess I could trade for some 00 tails that are red and just put on the red signal overlay.
stock are the 02 clear ones.
I had a guy paint the altima ones a few years back, but I lost his contact info.
Old Dec 7, 2008 | 07:14 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
(1) The lights will have to be off the car
(2) Stick the overlays on top of the computer for about 2 hours before you use them; this will warm the vinyl up and make it far easier to work with
(3) Start in the middle, working out to the edges
Old Dec 7, 2008 | 08:07 AM
DrunkieTheBear's Avatar
Turbo'd Saab
blow dryers help too...just don't heat it too much
Old Dec 7, 2008 | 08:20 AM
Yeah, I was thinking that too, but something like that in n00bs hands could easily lead to decoupling or burn marks
Old Dec 7, 2008 | 08:26 AM
Turbo'd Saab
well a heat gun could be worse
Old Dec 7, 2008 | 08:41 AM
It honestly doesn't look that bad.
Old Dec 7, 2008 | 08:53 AM
scarface4522's Avatar
i think they look pretty good too
Old Dec 7, 2008 | 02:50 PM
jasonmax's Avatar
they look fine.
Old Dec 7, 2008 | 04:17 PM
Bjs470's Avatar
from the pics it seems fine at least
Old Dec 8, 2008 | 10:00 AM
Prophecy99's Avatar
Incorrect.. You do not need to take the lights off whatsoever to get a good install period.
As others said.. work from the center out. The trick is get a spray bottle filled soapy water and have the taillight wet the entire time you are applying the vinyl.. and once you get the alignment the way you want push all of the water/bubbles out.
As for the difficulty it is definately hard... took me about a hour each side to get it all "worked" out.
If you searched more than once you would have found http://forums.maxima.org/5th-generation-maxima-2000-2003/343237-blue-batmobile-overlay-kits-6.html#post6536889
Old Dec 8, 2008 | 10:05 AM
How many ways are there to skin a cat?
Old Dec 8, 2008 | 10:10 AM
Prophecy99's Avatar
Many , and you can obviously take the lights off to do the job.. but imo it wouldn't make it any easier.
Old Dec 8, 2008 | 03:27 PM
Squirrel82's Avatar
Like you said just trade for some all red ones if thats the look youre going for.Then overlay the signal.
I had the all red ones but didnt like the way they looked so I sprayed some black on then and overlayed the turn signal.
Before and after:
I still have the 02 03 tails that Ill open up to paint the inside.
Old Dec 8, 2008 | 03:29 PM
Squirrel82's Avatar
Final
Old Dec 8, 2008 | 04:44 PM
KILLER. Good work, man.
I see you took the lights off to do this...
Old Dec 9, 2008 | 07:14 AM
Prophecy99's Avatar
yeah spraying's a diff story...
nice work body man... looks better than the oem se's
Old Dec 10, 2008 | 08:56 AM
gold4dsc's Avatar
Originally Posted by Squirrel82
Final
how did you get the tails to be so shiny just tinted mines and still looks kinda dull to me
Old Dec 10, 2008 | 09:11 AM
Teaner's Avatar
2003 Nisan Maxima
Final
jose did you crack the glass of the taillight to paint the inside??
Old Dec 10, 2008 | 10:19 AM
Torgus's Avatar
Final
they should have come stock like this. looks great. good job.
Old Dec 12, 2008 | 03:26 PM
Squirrel82's Avatar
Thanks fellas.All I did was spray black paint and then clearcoat on the outside of the lens.
Old Dec 26, 2008 | 10:24 PM
Blue_Batmobile's Avatar
From the pictures they look great! Mind if I add them to my Gallery? Heat from a hairdyer and some patience is the key to a good install. I personally dont take the tails off when applying my taillight Overlays, but some people find it easier that way. Its all about personal preference .
Bat™
Old Dec 28, 2008 | 07:58 PM
croser2's Avatar
Sure you can use them, and yes, from there they look good but up close its pretty bad.
Yes, I researched all the methods and tips. Used a squeegie, card, hair drier, spray bottle of soapy water, and plenty of time. I just could not get the bends. Up close, they do look bad.
Old Dec 28, 2008 | 08:19 PM
You need to get a larger piece, then. Depending on how stiff a material may be, you will need to extend the fold points out by having a larger piece of material.
14GmMax
59
Aug 4, 2019 11:26 AM
05RLS2
Nov 7, 2016 05:52 PM
Redfox
Sep 28, 2015 10:41 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
