Instrument Cluster Removal
Old Dec 8, 2008 | 07:17 PM
jocoo's Avatar
Alright so I tried searching and searching on how to remove the instrument cluster from a 2002 Nissan Maxima but was only able to find 4th gen removal and partial 6th gen but no 5th gen. Can anyone point me in the right direction on how this can be done or where I can find my answer? Thanks.
P.S. Since we're on the topic is it possible to switch the lights behind the cluster or are they LED not bulbs?
Old Dec 8, 2008 | 07:25 PM
pmohr's Avatar
No more Maximas...
BT-30 explains how to remove it, BT-32 shows how it's all put together.
Metal Maxima's Avatar
SHIFT_om nom nom nom
Jocoo, where are you in NJ? You can swing by my place and I can help you out with this.
Old Dec 8, 2008 | 07:38 PM
03VQMAX's Avatar
2 screws to take off on the top part of the cluster trim, unplug dimmer switch, then you see the cluster, then take off the 3 screws holding it.
Old Dec 8, 2008 | 07:45 PM
imported_D_Roc's Avatar
might be easy if you take the steering coloum's cover off then take the 2 screws on the top pull that trim out then there will be 3 screws voila the cluster will come right out
Old Dec 8, 2008 | 08:01 PM
03VQMAX's Avatar
yea it will be easier to take off that cover, i never did it, i just squeezed carefully, thank god i didn't break anything.
Old Dec 8, 2008 | 10:51 PM
The Law's Avatar
I R The Law
The removal of the cluster is very easy!!! Take off the steering column cover off, then the 2 screws on the trip and there will be screws holding the cluster. After removing the screws it should come out with ease.
Old Dec 9, 2008 | 04:40 AM
phatboislim's Avatar
bulb size for the cluster bulbs?
Old Dec 9, 2008 | 06:41 AM
03VQMAX's Avatar
#24 which i believe its a T6.5, very hard to find. I think Autolumination are the only people that carry it, that's what i have in my cluster, fits perfect. I think a #74 is too small.
Old Dec 9, 2008 | 07:36 AM
i wana do my interior amber which is why im asking. i need to do my climate control because 1/3 of it isnt lighting up so i figure do it all at once...74 is for the climate control right
Old Dec 9, 2008 | 10:51 AM
Thorzdad's Avatar
This how-to for adding chrome rings to the gauges has easy-to-follow directions on removing the cluster.
Old May 27, 2010 | 01:40 PM
a33_ridah's Avatar
can anyone else confirm the t6 led bulb swap size?
i have found some and want to make sure they would fit
Old May 3, 2012 | 04:15 PM
Calvin Sanz's Avatar
We are on the same page jocco, except that my maxima is a 03 but still is the 5th generation. We are on the same situation, let me help you out a little bit. First of all, these can be replaced with LED's I do have them already, and I bought them online from www.superbrightleds.com and you have to order the same ones I just order. 74-CWHP3 Mini Wedge Base 2 volts. You need 4 Cool White Hight power Led. ( That was description of the product you need ) Now I am working on my research as well as you. Email me if anything buddy. silver_dreamer08@hotmail.com.
Good luck.
Old May 3, 2012 | 04:19 PM
CustomLowz's Avatar
Good luck.
you do realize this thread is almost 4 years old.....
Old May 3, 2012 | 04:34 PM
cjandura's Avatar
WOW THE SEARCH FUNCTION WORKS WONDERS THERE ARE WRITE-UPS THAT COVER THIS!!!!!!!!!!!!!!
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
