ES motor mount question....
Old Dec 25, 2008 | 12:47 PM
kcxd35's Avatar
I installed them and i'm really hoping that they will break-in cause since the install my car starts hard and there's a good bit of vibration in the cabin...
How long do they take to break-in?
Does your car start hard?
Should I do the idle air procedure?
just some pics because lol....
Old Dec 25, 2008 | 01:45 PM
whiteSE's Avatar
i didnt know we had to break them in. i put mine on, and its ok. just a little rattle when idleing
Old Dec 25, 2008 | 01:52 PM
SpooledVQ35's Avatar
cold weather has alot to do with it as well.
Old Dec 25, 2008 | 02:06 PM
kcxd35's Avatar
I figured the cold is keeping it extra stiff, hopefully it will soften up cause my god, the car feels like a race-only car and not a family sports sedan lol....
Old Dec 25, 2008 | 02:19 PM
Puppetmaster's Avatar
They won't get much "softer", maybe a little, but its more that you'll just get used to it. Plus it's only at idle, once you're in motion you don't really feel it.
What does the idle air have to do with the motor mounts? Or were you referring to a separate issue?
Old Dec 25, 2008 | 04:40 PM
kcxd35's Avatar
I thought maybe the engine sensors would read more engine movement and slightly raise idle to smoothen it out...I could be all wrong, I give it till about summer time or it's back to stock...
Old Dec 25, 2008 | 05:09 PM
NisTech's Avatar
you may have to to adjust your knock sensor to the more vibration. Otherwise your ECM goes into fail safe and your airflow meter will get false reading. This is particularly problematic if you have headers and have O2 simulator where that tricks your ECM software thinking you actually have O2 sensors installed while they actually generate some dummy voltages to show that everything is ok so you won't get a MIL light on. However from the pics it looks like it is not your case.
Also you cannot blame me but i had to write this haha. Sorry bud. just j/k
Old Dec 26, 2008 | 04:13 PM
kcxd35's Avatar
UPDATE:
Ok doing the idle air procedure fixed my problem, My car adjusted itself and it starts and idles just fine now, Maybe i just got used to it like they said but it feels alot different after I did that... Anyway i'm happy.. =O)
Old Dec 26, 2008 | 07:48 PM
nismowolfe's Avatar
wheres a good place to get these I might be interested thanks.
Old Dec 26, 2008 | 08:32 PM
whiteSE's Avatar
eaby. but it took them a month to ship mine
Old Dec 26, 2008 | 09:01 PM
maxboy325's Avatar
Cattman in the group deals forum
Old Dec 26, 2008 | 09:20 PM
kcxd35's Avatar
I got mine from http://suspension.com/nissancars.htm
Got it with-in 3 days and they have very good prices...
I'm gonna take a video of the idle so people can what it will be like after there install...
Give me a couple hours...
Old Dec 27, 2008 | 09:21 AM
mist max2000's Avatar
sweet... waiting for video .. might as well get an underhood shot,. and an in car shot
Old Dec 27, 2008 | 10:44 AM
kcxd35's Avatar
I took the video but when I review it you can't really notice the rougher idle, it's hard to hear from a camera maybe if I put a piece of paper on the steering wheel that might help, I will try it later but for now here is some pics and the video...
The reddish build-up in the pics is just some grease from the install, taking the old mounts out were a HUGE problem, they were like heat warped unto the metal of mount ring.
Here's the videos...
First start -
http://www.youtube.com/watch?v=leNSa5mXLu8
Engine warmed at Idle -
http://www.youtube.com/watch?v=vJq66S5xYZc
Old Dec 27, 2008 | 11:58 AM
interesting,..how would u rate the install _/10 ...did you use a press?
Old Dec 27, 2008 | 12:03 PM
kcxd35's Avatar
Yes I used a press but it wouldn't get it out I ended up using an air mini jack-hammer sort of thingy and prying it out till it gave way...I would rate the install a 4 if everything goes well and nothing is stuck but if that mount is stuck to the holder then i give it a 9 cause getting it out is crazy but once it came out everything after that was a breeze and even taking the mount frame out is easy...
Old Dec 27, 2008 | 02:38 PM
Torgus's Avatar
i hear burning them out is the easiest way to go. glad you like em!
Old Dec 27, 2008 | 05:30 PM
whiteSE's Avatar
thats what i did...i threw them into the BBQ grill and let them cook, but i always had to add wood, and there was black smoke all over the place
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
