Time for a tuneup?
Old Jan 9, 2009 | 02:54 PM
  #41
Scottwax's Avatar
That's Mr. Detail to you
Originally Posted by Stereodude
How does a bad cat cause bad gas mileage?
It restricts exhaust flow.
Old Jan 10, 2009 | 06:14 AM
  #42
6spdmax's Avatar
Originally Posted by Chad Valk
every shop says that it'll easily get to 200k miles.
I just saw a 2003 Maxima for sale on autotrader with 215K mi.
testpipe FTW!
A friend is going to help me with the plugs, pcv, and rear vc. Then I'm going to help him with the plugs and pcv on his 3rd gen Altima 3.5. Anyone know if there is a similar issue with plug wells filling up with oil in those cars? Can it be improved with a newer vc? I'm going to post a similar question in an altima forum, but I thought someone on here might know.
Old Jan 10, 2009 | 06:38 AM
  #43
RLW001's Avatar
Wow. How can someone get to 215K on a 2003? That's alot of miles fast.
Old Jan 10, 2009 | 07:24 AM
  #44
Blitzfist's Avatar
testpipe FTW!
Im pretty sure since the altima 3.5 and the maxima have the same engine that it would be just as likely to have the valve cover issues. I just had it fixed on my car and I cant beleive how much better it runs.
Old Jan 10, 2009 | 07:48 AM
  #45
6spdmax's Avatar
Yeah that's getting after it pretty good. I guess it's feasible if someone drove about 1 hr. to work on the interstate, 5 days a week.
I bought my 03 in the beginning of 07 and it already had 84K mi. At least when someone advertizes "mostly highway miles", you know they're probably telling the truth.
Old Jan 10, 2009 | 07:54 AM
  #46
Scottwax's Avatar
I bought my '02 in November '07 with 113,897 miles on it. Less than 14 months later, I have 143,007. The original owners lived north of Dallas and commuted 60 miles a day, most of it freeway. I've been down to Austin and out to Kentucky with my car, plus I live in the middle of the Dallas-Fort Worth metromess and the rest of my family is scattered on the northern and eastern outskirts. Either of my brother's, my sister or my parents are a 90 mile round trip!
My ex-wife is a sales rep for Nabisco, she puts 30-40,000 a year on her company car. Probably the owner of that '03 has a similar job where they drove the car constantly. As long as it was mostly freeway and the oil was changed regularly the engiine is probably in decent shape.
Old Jan 10, 2009 | 08:59 AM
  #47
Stereodude's Avatar
The real question is how fast their engine was drinking oil at 215k miles.
My buddy has around that number of miles on an 03 and it sucks down 2+ quarts every 3k miles. Mine 02 with 115k miles uses about 1 quart every 3500 miles.
Old Jan 10, 2009 | 09:37 AM
  #48
Adik's Avatar
I had the same code appear early December. I waited a week or so hoping the light would go off with fresh fill up (has worked before on occassion). Fearing the O2 sensor failure again, I went to Autozone and they pulled the code. I had the dealer run it to get the specifics and they said left pre-cat. I was also due for plugs (104,225 miles). Their quote was steep, $790 just for the pre-cat and with labor and plugs I was up around $1300. Went to a local shop that I knew from others was reliable and they verified the left pre-cat that I told them was bad and they did that for no charge. Went with them and last week they put in the cat ($635 w/labor) and the plugs ($218, dealer wanted $225). Saved about $350 total. No joke on the plug labor, everyone said 1-1.5hr to replace those. Car has been purring for a week and half now. I typically have had all work done at the dealer, but holidays and the economy combined I had to try something different. I am not stingy about taking care of my car and every shop says that it'll easily get to 200k miles. Good luck with your repair.
thank you, I found one shop where they can fix my problem for $700 with labor for couple hours, but I want to save a lil bit more money... can you tell me pls a part number or exact name of parts I need to buy, I want to take a look on eBay, I already saved about $1000 on parts for my previouse car using eBay.
I already changed my plugs, I bought plugs at local dealership for 70$ and paid $40 to change it -)
Old Jan 10, 2009 | 10:04 AM
  #49
6spdmax's Avatar
I have 102K mi. on my 03, and I use a qt. every 800 miles.
Old Jan 10, 2009 | 01:38 PM
  #50
Scottwax's Avatar
Seems with our cars oil consumption is not based on mileage. Several here with low mileage and high oil comsumption. Mine goes through a quart every 1800-2000 miles and it has remained constant the entire time I've had the car.
My '74 Z/28 was using a quart of 60w oil every 50 miles and I had to screw in spark plug non-foulers into the heads so I would foul a plug or two A DAY!
Old Jan 10, 2009 | 03:33 PM
  #51
2k0to2k3's Avatar
just changed all my plugs and coils on my 2k with 90k and it made quite a diff. runs alot smoother for sure
Old Jan 10, 2009 | 03:51 PM
  #52
Blitzfist's Avatar
Before I had the valve cover fixed it was about a quart every 1000 miles. Im not sure what it is now but im sure this will reduce the consumption
Old Jan 10, 2009 | 06:23 PM
  #53
Scottwax's Avatar
I wouldn't count on too much change, it would have to be a pretty big leak to affect it that much.
Old Jan 15, 2009 | 08:44 PM
  #54
6spdmax's Avatar
Originally Posted by Berto210
where did you find that cd manual? I found a site, but its a pdf, but didnt tell me much about the pcv valve and the process for how to remove it.
The CD I got is also a pdf. There are a few diagrams explaining positive crankcase ventilation, on pages EC-52 and EC-53. To inspect the pcv:
With engine running at idle, remove PCV valve from rocker cover.
A properly working valve makes a hissing noise as air passes
through it. A strong vacuum should be felt immediately when a finger
is placed over valve inlet.
Is that the same pdf you were looking at?
From the schematic diagram, it looks like replacing a bad pcv could potentially make a big improvement in oil consumption. I guess I'll know soon enough.
Old Feb 21, 2009 | 11:40 PM
  #55
Nightrunner01's Avatar
Just pull and twist man
is there a trick to removing that pcv valve???
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
