Strut Mounts & other Pieces
Old Jan 3, 2009 | 11:11 AM
gr8ness97's Avatar
**This is the first I've ever done any suspension upgrades, so please bear with me. I have searched, but I need a visual reference **
The previous owner of this 02 Max 6MT that I have purchased has sorta trashed the car. The car had S-techs on stock struts and we all know what happens over time...blown struts.
Now, I'm trying to gather the parts to make the suspension good as new again. I have bought brand new Illuminas (most recommended on here from research) and now need to get stuff such as "strut mounts" and "bearing plates". I do know what the mount is, but I dont know to what extent do I need to buy items to replace.
Visual guide for suspension
Can someone guide me to what OEM or aftermarket pieces I may need to purchase so that I can order it and finally get my ride back on the road?
Old Jan 3, 2009 | 02:12 PM
djfrestyl's Avatar
Suspension Yoda
How many miles on the car?
#13 and #14 are most important, thats your strut bearing and strut mount (respectively)
Depending on the current condition of your bumpstops/dustboots will warrant if you need new ones. Anything over ~70k miles, I'd replace them if you're going to be doing the job anyway. They're #9.
Here's a better picture from courtesyparts.com
From the picture,
#13 = 54325
#14 = 54320
Old Jan 3, 2009 | 03:49 PM
gr8ness97's Avatar
Is there a certain place that .org members get OEM parts from?
Old Jan 3, 2009 | 03:50 PM
djfrestyl's Avatar
Suspension Yoda
Many of us call David Burnette at South Point Nissan. 512-444-1400. Just say you're an org member.
Old Jan 3, 2009 | 03:51 PM
gr8ness97's Avatar
Thanks!
Old Feb 11, 2009 | 06:28 PM
Burny's Avatar
is a spring compressor necessary to get to the strut mount?
Old Feb 11, 2009 | 06:51 PM
e-subliminal-2's Avatar
In order to SAFELY remove the springs from their housing you will need a spring compressor. You can rent one from autozone for $50 and return it once finished, they'll refund you fully after. A compressor IS NEEDED.
Old Feb 11, 2009 | 06:55 PM
correction, the actual mount (the 3 bolts i believe you're asking about) you do not need a compressor to remove. However the single bolt that holds the spring in place (the hat) you will need a compressor. If you're going to mess with the strut i'd reccomend getting the compressor just to be on the safe side.
Old Feb 12, 2009 | 05:10 AM
djfrestyl's Avatar
Suspension Yoda
Eh, on certain gen cars you don't NEED a spring compressor, but it helps.
Old Feb 12, 2009 | 05:24 AM
kukx30de's Avatar
I would also suggest putting in new coil isolators both upper and lower, new spring seats and that freaking $7 piece of triangular paper which sits right on top of the assembly.
That would be the only way to make your suspension feel like new again, if that is your goal
Good Luck.
Old Feb 12, 2009 | 06:00 AM
djfrestyl's Avatar
Suspension Yoda
You can use a manilla folder or something similar to replace that orange paper gasket. No need to spend the money
Old Feb 12, 2009 | 06:18 AM
kukx30de's Avatar
Yes that was what i was thinking about. But you need to treat the paper and make it waterproof plus it needs to be just the right thickness to avoid binding issues.
Old Feb 12, 2009 | 07:05 AM
djfrestyl's Avatar
Suspension Yoda
You're taking that piece of paper really seriously. It's not a huge deal. I've seen plenty of instances in which it's not even there and there are no 'binding issues' or noises, or any issues at all.
Old Feb 12, 2009 | 07:09 AM
Puppetmaster's Avatar
None of mine are on there and there are no noises whatsoever. Not saying it is right, just saying, it isn't a big deal.
Old Feb 12, 2009 | 07:44 AM
kukx30de's Avatar
probably... maybe true... when i re-did my suspension.. spoke to DaveB abt the parts and discussed it at length... it was from that discussion that i learnt about the purpose of that piece..
There can surely be instances of a part not being there. However, if it surely does not make a difference, why would a part be designed for a specific vehicle?
Old Feb 12, 2009 | 07:52 AM
I don't think anyone is debating the design, purpose, or even whether it makes a difference. We all know what it does and why it is there. All we are saying is, you can live without it - it is not a critical component, all other things considered. I've seen several set-ups, a few of mine included, without these gaskets that have had no noise or wear issues.
Old Feb 12, 2009 | 07:58 AM
kukx30de's Avatar
and I completely agree with your statement! I was not going in the direction of a debate anyways. Only stating what was told to me by someone
Old Feb 12, 2009 | 09:20 AM
SpooledVQ35's Avatar
if your worried about the paper, just use black rtv.
bigdogsteve
Jan 31, 2018 04:18 PM
D Mason
Jun 21, 2016 04:43 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
