Do our 5th gen autos really shift around 5950 rpm?
Old Jan 15, 2009 | 05:22 PM
Haterz's Avatar
I have been data logging some runs with logworks 3 and the innovate motorsports ssi-4 and it shows that the car shifts between 5934 and 5967 but the tach on the car shows around 6350 or so. Could this be accurate since the speedo is also known to be incorrect, especially at higher speeds? It reads the idle correctly showing 700 rpm once warmed up. Could my settings with logworks just be off? Anyone have experience with logworks and the ssi-4? I still do not have the speed settings for logworks figured out yet.
Old Jan 15, 2009 | 05:56 PM
pmohr's Avatar
No more Maximas...
Your tach is going to be off at higher revs, that's just how it is.
Typical WOT shifting as follows.
1-2: 5300-6000 RPM
2-3: 5500-5800 RPM
3-4: 5600-5800 RPM
That's a rough estimate on the RPM, you can check for yourself using this chart:
Old Jan 15, 2009 | 06:30 PM
Haterz's Avatar
This was news to me, is there anyway to adjust say using consult II? I would prefer it to shift at around 6500 if possible.
Old Jan 15, 2009 | 06:32 PM
pmohr's Avatar
No more Maximas...
Nope, don't believe you can.
Best you can do is get yourself a SupraStick, or do shift_fast.
Old Jan 15, 2009 | 06:34 PM
jasonmax's Avatar
mine shifts higher than 6000rpm.
donno why, maybe the 2nd-3rd slip.
http://www.youtube.com/watch?v=XPIKpfENLo4
Old Jan 15, 2009 | 06:36 PM
pmohr's Avatar
No more Maximas...
Are you judging when it shifts solely by your tach? The tach is going to be off at higher revs.
Old Jan 15, 2009 | 06:41 PM
Haterz's Avatar
mine reads 6300+ as well, but logworks is probably giving a more accurate reading of around 5900 rpm. it seems that our gauges are off.
Old Jan 15, 2009 | 08:15 PM
Scottwax's Avatar
That's Mr. Detail to you
Mine upshifts at full throttle anywhere from 6000-6300 as indicated on the tach.
Old Jan 15, 2009 | 08:53 PM
Haterz's Avatar
the issue is that our tach says 6000-6300 when it shifts but it is actually shifting at under 6000 rpm.
Old Jan 15, 2009 | 09:02 PM
Scottwax's Avatar
Hence the use of the word "indicated". I might mention the rev limiter does kick in on my car at an indicated 6700 rpm.
What is funny is that according to my GPS, my speedometer actually reads 1 mph slow at 60. Go figure.
Old Jan 15, 2009 | 09:24 PM
Haterz's Avatar
hey Scottwax, did you ever get that transgo kit, i remember you were interested in i read in another thread a while back?
Old Jan 16, 2009 | 09:55 AM
Scottwax's Avatar
Not yet. Still debating whether or not it is worth it with 143k on the transmission.
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
maxima-junky
Aug 13, 2015 09:59 AM
MaxStock
Aug 12, 2015 08:33 AM
