Radio antenna 00 se
Old Jan 26, 2009 | 05:34 AM
williamgd2's Avatar
Radio antenna 00 se
I have a 2000 se and the radio pulls in 1 station,I had the roof pillar trim off on the front right interior and found what looked like the antenna wire cut.My question is where is the antenna supposed to go in my Se?I have none visable.Thank you
Old Jan 26, 2009 | 06:24 AM
Nelsito65's Avatar
The antenna is embedded in the rear window, along with the defrosting lines. I'm not sure wich route the wiring for the antenna connection follows, from the radio to the rear glass, so I wouldn't know if the cut wire you found is the antenna connection.
Old Jan 26, 2009 | 06:45 AM
williamgd2's Avatar
Thank you NELSITO65 That is the information I was looking for.I think I will have to run a new wire but now I know where it goes.
Old Jan 26, 2009 | 12:00 PM
bigpimpen092's Avatar
good luck and be careful!
Old Jan 26, 2009 | 12:24 PM
VQP0WER's Avatar
Is this an aftermarket radio? Did you hook up the power antenna wire? (blue)
Old Sep 10, 2009 | 07:46 PM
akattamu's Avatar
What if my new radio does not have an antenna out? Can I wire power directly from the ACC on connection?
gavin68
Sep 18, 2021 12:36 PM
chisam14
Nov 6, 2018 08:56 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
DBear
Sep 14, 2015 08:33 PM
