00' EGR removal
Old Jan 29, 2009 | 12:25 PM
Fireonice's Avatar
00' EGR removal
I can not find much info on this. I would like to just get rid of the whole system.
This is the bolt to block off the manifold
http://www.courtesyparts.com/plug-taper-p-252025.html
This is the plate
http://www.courtesyparts.com/support-ma-p-251537.html
Now i'v done tons of thread searching and have not come up with much information except that leaving the EGR temp. sensor plugged in should keep my SES light off.
I understand a bunch of little hoses attach to the EGR. What do i do with the hoses?
Some help on this? Are there any other things i need to worry about or remove/block off?
Old Jan 29, 2009 | 12:42 PM
Progress's Avatar
It's business time.
What year is your Maxima? Why on earth do you want to get rid of your EGR?
Old Jan 29, 2009 | 01:00 PM
ohitzme's Avatar
Why would you ever need that out of your car?
Old Jan 29, 2009 | 05:49 PM
oldngivout's Avatar
Willing to learn
I don't see how it would.
The EGR temp sensor feeds back to the ECU, telling it when the EGR system is operating or not. It does this by changing resistance based on the temp of the exhaust gas passing over it.
So, if it is not in the exhaust stream, how could it possibly do that correctly?
Old Jan 29, 2009 | 06:22 PM
secondtonone317's Avatar
nycnissans
I am going EGR less also, FYI 2001 maximas do not hav EGR.
Old Jan 29, 2009 | 07:19 PM
Fireonice's Avatar
my 2000 does guys...
Old Jan 29, 2009 | 07:28 PM
AceofSpds's Avatar
wat
have fun, im sure you will enjoy all the little exhaust and vac. leaks that will occour over time from doing this.
Old Jan 29, 2009 | 07:58 PM
Progress's Avatar
It's business time.
Yes, 2000s have them, 2001s don't. You think 2001s are that much faster than 2000s?
Old Jan 29, 2009 | 08:17 PM
pmohr's Avatar
No more Maximas...
Why do you say there's going to be exhaust and vac leaks if this is done?
Remove all of the vacuum lines for the EGR system, install the exhaust manifold plug and intake manifold block off plate, plug the one or two manifold nipples that are now unused, problem solved.
Old Jan 29, 2009 | 09:01 PM
Fireonice's Avatar
There we go pmohr a little more information .
And what leaks occurring overtime does aceofspds speak of? And exactly how is this possible if i'v already removed the vac lines and blocked everything off...
As for leaving the temperature sensor plugged in to not throw the SES light. I read that on the 4th gen forums. A couple members stated that.
I'm still not 100% sure i'm going to go threw with this but it sure as hell beats cleaning the damn thing every so often as i'm turning this car into my daily beater. Looking to get 300k++ miles w/ some minor bolt ons for a little extra powa.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
