How do these plugs look?
Old Feb 2, 2009 | 10:39 AM
OhOhMax's Avatar
Every once in a while when I start the car, after it has already been driven and the motor is still a little warm, I will be able to tell right away that it has a weird feeling idle going on, then when I put the car in gear you can feel that its got a miss fire going on. Turn the car off and re-start it and it's still there. Turn the car off and let it sit for a half hour to a hour to let it cool down then start it back up and it goes away.
I changed the coils about 50 or 70K miles ago with the updated coils, so I am hoping that it is not a bad coil. I was hoping to pull the plugs and see one plug that was obviously fouled out or something along those lines, but they all look relatively the same to me, and they all seem to be charcoal colored, so like they are all burning stoichiometric (not lean or rich). So to me they look like they are all burning just fine, but I could be wrong. I'm changing them out with some NGK Iridium plugs and hopefully they will go away.
The old plugs were Denso Iridium's.
----------------------------------------------------- driver rear ------------------------------------------------------------- passenger rear
----------------------------------------------------- driver front ------------------------------------------------------------- passenger front
Old Feb 2, 2009 | 10:57 AM
pmohr's Avatar
No more Maximas...
Never was good at reading plugs, but at the very least looks like the front bank is running richer than the rear.
FWIW your rear valve cover is leaking.
Old Feb 2, 2009 | 11:01 AM
DrunkieTheBear's Avatar
Turbo'd Saab
Plugs are fine.
Old Feb 2, 2009 | 11:25 AM
OhOhMax's Avatar
Yeah, I thought they looked fine as well, just needed to hear it from someone else, hah. I really hope I don't have to buy another set of coils, I guess next time it happens I'll start disconnecting coils to figure out which coil(s) it is.
Old Feb 2, 2009 | 11:36 AM
Turbo'd Saab
You can test them easier then that...
http://forums.maxima.org/5th-generat...ow-w-pics.html
If your front coils are bad...I'm selling a set of front ones
TKHanson
Nov 24, 2018 01:39 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
