Magnetic Drain plug for manual trans?
Old Feb 4, 2009 | 08:36 AM
02nissmax's Avatar
Anyone know if they make a magnetic drain plug for the manual trans?
Old Feb 4, 2009 | 01:34 PM
pmohr's Avatar
No more Maximas...
If you check the clearances behind where the stock plug is, you might be able to use the Z33 diff drain plug. Those are magnetic, and are only ~1/2" longer than the regular ones. They should be the same thread pitch.
Why do you want a magnetic plug? There's already a magnet in there.
Old Feb 4, 2009 | 03:41 PM
02nissmax's Avatar
to collect loose particles.
Where is there a magnet in a manual transmission? Never heard of that
Old Feb 4, 2009 | 03:44 PM
pmohr's Avatar
No more Maximas...
There's a magnet in most every manual trans.
The magnet sits in the half-moon depression just forward of the diff (highlighted in red):
Magnet:
Old Feb 4, 2009 | 03:47 PM
maxximaa's Avatar
does AT have one?
Old Feb 4, 2009 | 03:49 PM
pmohr's Avatar
No more Maximas...
Yes, two in the pan.
Old Feb 4, 2009 | 03:50 PM
secondtonone317's Avatar
nycnissans
yes the auto has 2 in the pan, at least my altima had it I assume its the same with the maxima
Old Feb 4, 2009 | 03:55 PM
maxximaa's Avatar
sweet, is that pic from service manual?
Old Feb 4, 2009 | 03:56 PM
pmohr's Avatar
No more Maximas...
Yes.
Old Feb 4, 2009 | 05:27 PM
02nissmax's Avatar
Interesting, didn't know that. I know that rear wheel drive manuals don't have one.
I'd still would like a magnet though that I can inspect, the one inside the trans you really can't take out unless the trans is taken apart, can you?
Old Feb 4, 2009 | 05:43 PM
pmohr's Avatar
No more Maximas...
Correct, you need to remove the rear housing to access that magnet. That one is going to be stronger than pretty much any magnetic drain plug you can put in, so any metal shavings are likely to go to the original magnet.
What do you mean RWD manuals don't have magnets?
Off the top of my head, the FS6R31A and the T56 both have magnets in the case housing.
Old Feb 4, 2009 | 07:09 PM
02nissmax's Avatar
Maybe some do, I'm still looking for the magnet inside of the trans of a S2000. I could be wrong again but not sure T5's had a magnet.
Good that the T56 has it. Might be buying one.
knight_yyz
Nov 6, 2015 02:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
foodmanry
Sep 24, 2015 12:02 PM
Socalstillen
Sep 20, 2015 11:46 PM
markevans999
Sep 10, 2015 04:29 PM
