windshield nozzle not working
Old Feb 7, 2009 | 07:26 PM
Amit56's Avatar
My driver nozzle does not spay out fluid unless I pop the hood, only the passenger side works. The rubber hose is obviously being pinched. Anyone ever ran into this problem, if so how did you fix it? I always had this problem ever since I purchased my car but I never really used it until now with the snow.
Thanx
Old Feb 7, 2009 | 07:51 PM
pmohr's Avatar
No more Maximas...
Did you try rerouting the hose? Keeping it away from where it's being pinched?
Seems like the first course of action...
Old Feb 8, 2009 | 04:48 AM
johnnyd2k2's Avatar
I had the same problem but the hose wasn't being pinched the nozel was just clogged I stuck a pipe cleaner in there and it cleared right out and its been fine ever since.
Old Feb 8, 2009 | 07:25 AM
Progress's Avatar
It's business time.
Do you have a FSTB?
Old Feb 8, 2009 | 07:27 AM
CustomLowz's Avatar
Thanx
I had the same exact problem, and it baffled me... What I ended up doing was chased the hose to the drivers nozzle, and pulled it out from behind the insulation on the hood. I just ran it in front, and it has worked fine since... Strange...
Old Feb 8, 2009 | 07:50 AM
nsnrider's Avatar
take it out and blow it out with air gun, then reinstall it and trace out the lines. You should be able to see where it might be pinching.
Old Feb 8, 2009 | 06:26 PM
Amit56's Avatar
Originally Posted by Progress
Do you have a FSTB?
Yes I have a FSTB? Please don't tell me that's pinching it. LOL
Old Feb 8, 2009 | 06:33 PM
Progress's Avatar
It's business time.
My driver side nozzle stopped working (worked intermittently) after I installed my FSTB.
Which do you have? I have the Ebay one and after I adjusted the brace (made sure it laid flat and wasn't tilted) it started working again.
Old Feb 8, 2009 | 07:13 PM
Amit56's Avatar
ok let me check that out. I have no clue what FSTB i have.
Old Feb 9, 2009 | 09:00 AM
CMax03's Avatar
pull down the hood insulator and reposition the hose, it's being crushed by the FSTB!
Old Feb 9, 2009 | 12:18 PM
vball_max's Avatar
Happened to me as well.
Old Feb 9, 2009 | 05:51 PM
4DSCDriver's Avatar
I'm glad you started this thread. I have the same issue with my passanger nozzel. I think mine is a combination of an Ebay FSTB and too much wax in the washer nozzel. Now I know what to look for.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
