Utec
Old Feb 18, 2009 | 05:18 AM
N16_VQ_SWAP's Avatar
Utec
hello
which wiring /terminals are important to install the Utec into a 5.5 maxima?
thanks
Old Feb 18, 2009 | 05:38 AM
Puppetmaster's Avatar
IIRC, it'll just be similar to the Emanage Ultimate... basic ones would be:
Injector signal (for all cylinders)
Ignition signal (for all cylinders)
MAF
TPS
Knock
Power (probably ECM power)
Ground (probably ECM ground)
I'm sure there are more.... I'll see if I can find a good thread.
And because the UTEC is set up for a 350Z/G35 type ECM harness, you'll need to do some remapping using the Z33 wiring diagrams.
PM SurraTT, I know he's worked on this before.
Old Feb 18, 2009 | 05:41 AM
Okay, here you go:
http://forums.maxima.org/all-motor/570679-utec.html
Old Feb 18, 2009 | 05:48 AM
yes i read this post but what is with cam senor 1 +2 ?
Intake Temperatur? and the rest?
i have pm'd supra tt.. but he is not online......
thats my wiring
but not go
Old Feb 19, 2009 | 11:55 AM
which terminals must i connect?
Old Feb 20, 2009 | 01:24 AM
I have make a list, can you check it?
Injectors:
1, 3, 12
2, 11, 13
Ignition:
5, 7, 16
6, 15, 17
Crank Sen:
95
Cam Sen. 1: ???
65
Cam Sen. 2: ???
85
Knock Sen. :
71
MAF:
62
Intake Temp. : ???
66, 80
TPS1:
83
TPS2:
84
Power ECM: ???
110 or 43 or 42
Ground ECM: ???
106, 107, 108
IVT 1: ???
IVT 2: ???
O2 ?? ???
APS1: ???
73
APS2: ???
74
Throttle Control Motor: ???
101, 103
Is all correct ??? anything forget?
Old Feb 21, 2009 | 10:31 AM
hello???
Old Feb 21, 2009 | 02:32 PM
SurraTT's Avatar
HR Swap Pioneer
dude its a lot more complicated than that.
if u have a 02 max ECU u have to compare the max pinout to the 350 pinout and figure out what is what. obviously the wires arent in the same order/layout........
one of those measure twice and cut once deals here...
so do you have anything hooked up, or what are you doing??
is ALL you need is what wires to hook up?? if so then its just the basic tunning stuff,
http://forums.maxima.org/all-motor/5...0-px-wide.html
Old Feb 21, 2009 | 02:39 PM
SurraTT's Avatar
HR Swap Pioneer
ok so i looked at the pic, and i see u put the max connector on the utec..
soo now ur trying to put the 350 plug on the engine harness????
if so. then it does not matter what wires the utec uses if all are going to it ne way
sooo umm did u hook the right utec wires into the max plug??????
Old Feb 22, 2009 | 12:48 AM
noo the pic is old. i cut all.
and now i need only the the right pins to connect the utec. NOT fully plug and play! I need only the once wires.....
is the list correct?
which pins are important for the Utec?
Old Mar 12, 2009 | 07:17 AM
hello
i have connect all important pins but whats with the pin 34 ? RPM.. need the Utec this?
thanks
Old Mar 12, 2009 | 08:01 AM
pmohr's Avatar
No more Maximas...
Originally Posted by N16_VQ_SWAP
hello
thanks
The Z33 DE doesn't have an RPM output at the ECU, the UTEC uses other means to determine RPM.
Old Mar 12, 2009 | 01:08 PM
Ok... but why dont start my car with the Utec? without runs good.....
Old Mar 12, 2009 | 01:11 PM
pmohr's Avatar
No more Maximas...
Well have you checked why it's not starting? Fuel, spark?
What map are you on?
Old Mar 13, 2009 | 06:54 AM
hello
i have connect all cable new, complete new wiring and i think its all correct connect....
spark, injectors Walbro pump runs before and not with the utec now....
I have install the 2.8 software on the Utec... map? i switch it on position 0, the utec use the original specification from max ecu or?
I dont can connect the utec with my laptop... i have windows vista installed and dont works... Windows vista dont have hyper terminal... which program can i use for perfect work/connection under windows vista?
do you have the utec in your car?
I ahve a 02 max engine with following mods:
- 350z complete intake manifold
- 350z injectors
- 350z thermostat
- iridium sparks
- 350z fidanza flywheel
- exedy stage 1 clutch
thanks for your help
Old Mar 13, 2009 | 07:21 AM
pmohr's Avatar
No more Maximas...
So no spark and no fuel now?
Have you triple checked all of your connections, and pinouts?
Old Mar 13, 2009 | 07:27 AM
Deckdout2's Avatar
Play with my balls
hello
- 350z injectors
- 350z thermostat
- iridium sparks
Just found out that with Vista, you have to make hyperterminal active. You might have to go into the control panel or windows settings and turn that feature on. I didn't think that it had it either, but my roommate found it. Probably want to google search that one.
Old Mar 13, 2009 | 07:37 AM
tonedef's Avatar
just by a cheap lap top with xp, or 98.......
Old Mar 13, 2009 | 10:15 AM
no no fuel is going... spark i dont no.....
into the utec software download is hyper terminal 6.3 but i dont come into the utec main menu.. i think its dont connect to the utec.....
when i switch the utec of MAP 0, used the utec the original max configuration?
i have patched the new version ( 2.8) on the utec.... so the old maps of the utec its delete or??
S H I T utec i hate it now.... i will start my engine....
its run without utec! here is a movie from it....
http://www.youtube.com/watch?v=oUXpSliXvJM
But i have a Nissan Almera N16 ( Sentra XE B15 ) an swap a 3.5 V6 into....
Old Mar 13, 2009 | 11:03 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Sounds like your pinouts are wrong. Remember you need to get a wiring diagram of the 350z ECU and one of the maxima and match up the pinouts. The way I did this was to make a chart with the things I needed IE what puppetmaster listed:
"Injector signal (for all cylinders)
MAF
TPS
Knock
Ground (probably ECM ground)"
then put a column for 350z pins and another for maxima pins, then write down which ones go to each. From there you can isolate the 350z pins/wires that are on the UTEC and connect those to the correct wires on the maxima harness/ECU.
Old Mar 13, 2009 | 12:29 PM
i use this page for the correct connection
i drive tomorrow to my garage and make pics for you..... iam sure my wiring is correct...
The 350z and max have the same cranks sensor?
its windows not combatible with the utec? i install hyper terminal 6.3 ( its into the 2.8d software package) put i dont open me the utec menu.....
i dont have a old pc or laptop with windows xp /98se......
and a other program for the utec?
when i connect the utec with the hyper terminal then i have a whit screen into the window....
Old Mar 17, 2009 | 12:42 PM
i have a new pic
But the engine dont start ....... wiring its all checked and OK
whats wrong?
My OBD Tool tell me mistake 335 Crank posi sensor.... i have installed the 02max sensor... must i need the 350z now???
chris
Old Mar 19, 2009 | 12:58 PM
Old Mar 19, 2009 | 01:39 PM
pmohr's Avatar
No more Maximas...
You mean P0335?
The Z33/A33B CKPS' are identical.
More than likely you damaged the CKPS wire, or tapped into it incorrectly.
Old Mar 19, 2009 | 02:37 PM
SurraTT's Avatar
HR Swap Pioneer
+1
if your getting crank pos sensor code. then check that pin, and the wire..
and my 02 max actually ran with out a crank pos one time. so idk if utec will allow that. but some how my car did. it just took 20 seconds or so of cranking.
Old Mar 19, 2009 | 02:43 PM
pmohr's Avatar
No more Maximas...
Originally Posted by SurraTT
+1
Yep, they'll run just fine without a CKPS on there, but IME it'll take forever to start up (reverting to getting timing info from the CPS', my best guess), you'll have no tach, and it'll be down on a bit of power (disables CVTC and reduces engine power on purpose, I believe).
Old Mar 20, 2009 | 02:50 AM
without ckps runs the engine? why my not? ok i check the wiring
again, but i think the wiring must be ok.......
S H I T VQ swap .....
hey SurraTT please come to my to germany and help me ;-)
i think the 350Z becomes the tach over canbus.....
Old Mar 21, 2009 | 10:15 AM
hello
please look at my picture from utec... the TPS is at 72% is that OK ?? The engine is NOT running!!!
Its to high, or???
I have check the POWER and Mass from ign coil, injectors, Crank pos, cam posi MAF... its all ok.....
Have one of the Utec user here a pic from his utec? ( engine dont run! )
edit:
I have found a pic at the 2.8d download file
and here is my file
PLEASE LOOK AT TPS
Old Mar 24, 2009 | 01:05 PM
hello
i have deinstall the Utec... now runs only my maxima ECU and the engine runs good....
So what is the problem??? Whats wrong?
thats all connected:
MAF
TPS
Knock
But TPS, all TPS wiring or only TPS 1 signal ??
And MAF only signal or all from MAF ???
Is one guy here, it have
successfully run into max???
Old Mar 24, 2009 | 01:21 PM
SurraTT's Avatar
HR Swap Pioneer
so whats the problem????
when the utec is in the motor dont run. ok
does it crank???
getting Fuel?
spark?
there is no "hook this up" and it will work just fine answer......
Old Mar 25, 2009 | 06:12 AM
hello
yes when the UTEC is out, the engine runs..... Utec is in engine not run.....
Fuel OK
CKPOS is brocken,but the engine runs without Utec
spark all 6 signal connected
Can you tell me which pins exactly for the right connection?
SPARK:
Pin: 62 , 61 , 60 , 81 , 80 , 79
INJECTOR:
Pin: 23 , 22 , 21 , 42 , 41 , 40
KNOCK SENSOR:
Pin: 15
CKPOS:
Pin: 13
MAF:
Pin: 51
No Intake temp, ground or power?
TPS:
Pin: 50
Only TPS 1? whats are with TPS2, throttle actuator, throttle relay?
Ground:
Pin: 1 , 115 , 116
Power:
Pin: 109 , 119 , 120 , 121
And whats are with the rest?
IVT , cam posi 1 + 2 ?
Have you successfully connect the Utec into max and runs the car?
here a movie w/o Utec and the engine run
http://www.youtube.com/watch?v=bYOFBuVikcU
Old Mar 25, 2009 | 06:21 AM
SurraTT's Avatar
HR Swap Pioneer
if you are hooking those wires up, it should def run
Old Mar 25, 2009 | 06:27 AM
hmm... but it dont start.
I have download the base map and parameters from TurboXS
And install the 2.8d version....
must i modify any settings into the base map or is the base map so ok?
Old Mar 25, 2009 | 07:49 AM
Deckdout2's Avatar
Play with my balls
Can you provide a picture or 2 of what exactly you have going on there? With the wires spliced from the UTEC and 1 of where it's actually connected to the ECU.
Old Mar 25, 2009 | 10:03 AM
SurraTT's Avatar
HR Swap Pioneer
that dont matter, if the utec is on 0 which is stock ECU,
if the car dont start/run on map 0 then its a wiring problem
Old Mar 25, 2009 | 10:33 AM
Deckdout2's Avatar
Play with my balls
+1
Old Jul 1, 2009 | 07:39 AM
hello
i have the Utec new installed but the engine dont start with the utec.
PLEASE PLEASE help me!
Here are pics from all
Old Jul 1, 2009 | 07:46 AM
more pics
whats the mistake?
Old Jul 1, 2009 | 09:51 AM
pmohr's Avatar
No more Maximas...
So again, why won't it start? Fuel? Spark? Have you checked anything?
Old Jul 1, 2009 | 11:10 AM
SurraTT's Avatar
HR Swap Pioneer
Holey Wiring Batman!!!
