turning and makes a metal on metal noise
Old Feb 22, 2009 | 09:47 PM
Max00se's Avatar
when i only turn left coming from the front right i hear a weird noise kind of a metal on metal grind..what is this?
Old Feb 23, 2009 | 04:45 AM
twstdstng's Avatar
wheel bearing noise?might be a brake rubbing?
Old Feb 23, 2009 | 07:39 AM
n3985's Avatar
大陆弟弟
Your steering bump stops, which are brittle plastic caps broke off. $2/piece from dealer, look behind the brake rotor and you should see a lonely bolt sticking out towards the engine.
Old Feb 23, 2009 | 07:56 AM
Ephraim's Avatar
what is it actually grinding against?
Old Feb 25, 2009 | 05:27 AM
jkenosh's Avatar
the piece of metal the brakes mount to
Old Mar 1, 2009 | 06:12 PM
Max00se's Avatar
ok thanks i will take a look at it
Old Mar 1, 2009 | 06:28 PM
HotMaxx02's Avatar
+1 for wheel bearing... I have had to replace both of mine
Old Mar 1, 2009 | 06:49 PM
Progress's Avatar
It's business time.
Does it make a "clang, clang" sound that is faster at a higher speed or is it just constant when turning regardless of speed?
Old Mar 2, 2009 | 07:59 AM
tooreckless00's Avatar
Mine goes away when the wheel is turning back but otherwise its always there too. couldnt figure outt what it was. so annoying
Old Jul 5, 2009 | 02:56 PM
myrcgarage's Avatar
Sorry that it is an old thread, but I have something similar with my 2004 Infiniti I35. When I make a right turn in the morning or after it parks for a few hours in a cool/cold day, it would make this grinding or metal to metal noise (only right turn). Then, after it is warmed up (5 mins or so), the noise is gone. Also, when it is going from 1st to 2nd or 2nd to 3rd gear, I hear this rumbling/groan noise (the first min or 2 in a cold/cool day). I have no idea what it is. Could it be this "Your steering bump stops" issue that "n3985" mentioned?
Infiniti dealer replaced the front driver side wheel bearing and it is still doing the same thing after that. I am afraid that it is a transmission issue. My extended warranty is going to run out in May of 2010. Any help is greatly appreciated.
Old Jul 5, 2009 | 05:51 PM
ridinwitha35's Avatar
If it is your bump stops, at least that's an easy fix & takes two seconds to diagnose....but the stops are only there for when you turn the steering wheel all the way left or right. I think they "stop" at the LCA.
I think you have the problem that we have in the following thread, which alludes to a Power Steering issue: http://forums.maxima.org/5th-generat...rting-car.html
Old Jul 5, 2009 | 08:22 PM
myrcgarage's Avatar
Thanks a lot for pointing me to another thread. The only difference between mine and the other person's problem was the "Groan/rumbling" noise when going straight.
Old Jul 5, 2009 | 08:33 PM
hi-tek22's Avatar
wheel bearing!
if its been doing it for a while the wheel hub is probably shot as well......might as well go ahead and replace both the bearing and the hub. The same thing happened to me all within six months of one another on the front of my car
Old Jul 5, 2009 | 08:44 PM
myrcgarage's Avatar
Originally Posted by hi-tek22
wheel bearing!
Dealer already replaced the bearing and the hub a few months ago. Nothing changed after that
alixc
Aug 11, 2020 01:48 PM
PH98I30
19
Jun 13, 2016 02:38 PM
boomerbrian
Nov 8, 2015 05:10 PM
kirkhilles
Aug 8, 2015 10:53 AM
