5.5 gen camber ?
Old Feb 23, 2009 | 12:50 PM
nissandrvr98's Avatar
5.5 gen camber ?
so i'm looking to drop the max a bit-either the search is down or there's really little chatter about it but i'd like to know...how necessary is a camber kit. looking for any info about this as i've heard too many conflicting stories.
much appreciated!
Old Feb 23, 2009 | 01:01 PM
PulsarGTS's Avatar
Its not needed. The rear is not adjustable and the front gains very little camber.
Old Feb 23, 2009 | 05:07 PM
knight_yyz's Avatar
Toolie
how much camber can we have on the front before we have to start worrying about tire wear? I'm not thinking ricey looking 5* or anything, but I'm thinking of getting a 1.5* kit for the front.
Old Feb 23, 2009 | 05:51 PM
johnnyd2k2's Avatar
I just dropped 1.25" and aligned perfectly within specs with no camber kit. IIRC its only needed for 1.5+ drops.
Old Feb 23, 2009 | 06:10 PM
2slow's Avatar
At 1.25" drop, what was your camber?
I plan to lower, and would like camber bolts to increase negative camber rather than remove it. Somewhere around -1.5 degrees as knight mentioned, would be nice.
Old Feb 23, 2009 | 07:07 PM
PulsarGTS's Avatar
You'll be fine at 1.5*, toe in/out eats tires faster than camber, so as long as there straight you'er good.
Old Feb 23, 2009 | 07:43 PM
knight_yyz's Avatar
Toolie
That's what I thought but wanted to be sure. Doing this in the spring.
Old Feb 23, 2009 | 07:57 PM
ZXTwnT300's Avatar
So what about when you use Progress spring which drop the front 1.7"? That is what I am putting on along with Illuminas when they get here later this week. Don't want to buy unnecessary parts and I know nissandrvr and I have been talking alot about this.
Old Feb 23, 2009 | 08:15 PM
knight_yyz's Avatar
Toolie
you only need the alignment kit if you are out of spec after the drop. Or if you want to go out of spec after the drop.
Old Feb 23, 2009 | 08:42 PM
nismology's Avatar
If you do a quick search you'll see that with progress springs the camber will still be within factory specifications. I found this out after I bought my camber bolts though.
Old Feb 24, 2009 | 05:36 AM
this is all very good to know...thanks all for your input
Old Feb 24, 2009 | 11:45 AM
ZXTwnT300's Avatar
Definitely, thanks for the input guys! I can't wait to get this stuff put on!
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
