Shopping around for clutches
Old Feb 24, 2009 | 03:17 PM
rosader's Avatar
My clutch is starting to slip so I've been shopping around. I will be getting the fidanza aluminum flywheel but there are two clutches i need to choose between, the Exedy stage 1 @ $410 or the Clutch Master Stage 1 @ $340. I like the price of the CM but is there a reason its cheaper than the Exedy? Are they similar in quality & reliability? I'm somewhat hard on my car and i want something that can handle the abuse. I will also be adding headers, Y-pipe, and exhaust.
Old Feb 24, 2009 | 05:53 PM
knight_yyz's Avatar
Toolie
I can't say anything about the CM as I have not used it. But I have the exedy stage one with the fidanza and I love it. had a bit of chatter when it was new but it is fine now. The pedal is a little stiffer than it was with OEM.
Old Feb 24, 2009 | 05:57 PM
Puppetmaster's Avatar
Some people like the SPEC and I recall also seeing some people happy with the Z33 OEM clutch, which will work with minor modification.
Old Feb 25, 2009 | 03:18 PM
rosader's Avatar
The search is not working and i cant seem to find information on Clutch Master are these as good as Exedy? Are they a better clutch than factory?
Old Feb 26, 2009 | 11:46 AM
SurraTT's Avatar
HR Swap Pioneer
i have the Z33 HR clutch its horrible worse thing i have ever done. im tempted to throw stock back on when im bored one day....
Old Feb 27, 2009 | 03:56 AM
6spdmax's Avatar
What's so horrible about it? Are you also running a Fidanza flywheel?
Old Feb 27, 2009 | 04:24 AM
Interesting, the last review I saw was good. I'll see if I can pull it up again.
EDIT: okay there have been mixed reviews on the Z33 HR clutch. If anyone is interested in going this route, you might want to do more research or talk to Derrick2k2SE as he seems to have had success with it.
http://forums.maxima.org/5th-generat...seal-pics.html
http://forums.maxima.org/5th-generat...-flywheel.html
http://forums.maxima.org/5th-generat...el-clutch.html
Old Feb 27, 2009 | 07:55 AM
rosader's Avatar
Puppetmaster, how do you like ur vq35hr clutch? IIRC I was reading somewhere that it is comparable to the exedy stage 1??? I just need something that can handle a little bit of abuse. How much did u pay for that clutch?
Edit: my bad I thought the links were about your car until i read the posts so nvm
Old Mar 25, 2009 | 08:07 AM
StillenMax80x20's Avatar
I found an exedy stage 1 disc for 51 dollars at partsgeek.com... do I need the whole kit?
I haven't really found any good answer for this. their clutch kit from exedy is only $181...
Anyway, what is included in a clutch kit
EDIT: Cheaper one here and free shipping
Man stuff has come down!
Old Mar 25, 2009 | 08:10 AM
secondtonone317's Avatar
nycnissans
I heard good things about RPS, and I can vouch for ACT but spec is a little eeeeehhhh.......
Old Mar 25, 2009 | 09:23 AM
SpooledVQ35's Avatar
Stay away from clutchmasters. I had the stage 1 and hated the thing. I took it out and replaced it with a nismo clutch and pressure plate from the z33 (350z) Direct bolt in. i also am using a fidanza flywheel..
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
RealityCheck
Oct 2, 2015 06:34 PM
Sep 27, 2015 08:37 AM
carlosvq30
Sep 26, 2015 09:44 AM
