Noisy Console Shift Interlock on 2K3 Automatic
Old Feb 26, 2009 | 10:24 AM
CVicVogel's Avatar
Max'ers:
I have searched for an answer to my problem.
When driving my automatic, each time I step on the brake, I hear a click from the shift console. It is the interlock, I think, that prevents the car from getting out of park unless you have a foot on the brake.
Well... it's getting louder and more annoying each time you press or release the pedal.
Is there a quick fix. Is there an easy way to get the console off to solve the problem?
Vic
Old Feb 26, 2009 | 11:40 AM
Nelsito65's Avatar
I started noticing that same sound when my car, some times, would not let me shift out park. It could have been always there, but I never noticed it before that. This started happening more often, up to the point that I had to start using the shift lock release button to get me going (I didn't realize that my brake lights weren't working either while I had this issue). In my case, it was a malfunctioning brake switch that I ended up replacing and the problem is gone. Your case could be a different part, if you are not having the symptoms I had.
Old Feb 26, 2009 | 12:20 PM
2002 Maxima SE's Avatar
Originally Posted by CVicVogel
Max'ers:
Vic
There is a TSB for the Altima (same year) that supplies larger rubber bushings to fix the noise. I thought about ordering it at one point but backed out (seems complicated in that area).
* TSB #02045 -- A/T SHIFT INTERLOCK SOLENOID CLICK NOISE. JG THIS BULLETIN REPLACES NTB02-045 DATED 04/15/2002. *TT (NHTSA ID #633632, SEPTEMBER 13 2004)
* TSB #NTB02045 -- AUTOMATIC TRANSMISSION SHIFT INTERLOCK SOLENOID CLICK NOISE. *JG (NHTSA ID #631332, APRIL 15 2002)
gigabyte
Jan 6, 2017 06:05 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
