3Bspec foglight install question
Old Feb 27, 2009 | 02:22 PM
nfisher50's Avatar
So I'm looking at this install and the H3 bulb is too long, therefore it doesn't sit in the housing fully. Also, the way that the harness is, it doesn't allow for the clip to be secured since is is 20 degress offset? Any one else install these in the fog lights and be successful
Old Feb 27, 2009 | 04:18 PM
IHAVEA2KMAXIMA's Avatar
I've heard that you have to push the reflector outward a bit to make the bulb fit. No clue on the harnass part.
Old Feb 27, 2009 | 05:22 PM
03VQMAX's Avatar
Yea, you might have to push the reflector outward a little, and as far as for the connections, it should be 2 female and 2 male connectors.
Old Feb 27, 2009 | 06:14 PM
Progress's Avatar
It's business time.
By reflector, do you guys mean glare shield?
Old Feb 27, 2009 | 06:34 PM
03VQMAX's Avatar
Yup.
Old Feb 28, 2009 | 08:39 AM
RLW001's Avatar
Just ask for the H3c bulbs and return the H3 bulbs. They are excellent to deal with.
Old Feb 28, 2009 | 12:20 PM
mist max2000's Avatar
.. i pushed my reflector forward,.. and hardwired mine..
Old Mar 1, 2009 | 09:42 AM
Jreed2008's Avatar
I did mine yesterday just used a flat head and push the reflector in a bit should do the trick and I don;t think it effects light output
Old Mar 1, 2009 | 07:37 PM
CMax03's Avatar
Yeah That's weird I just set up their phone service the other day, 3B Spec and his HID kits are super inexpensive or maybe cheap...I asked the guy 3 times where his product came from? Perhaps M.I.C. he still wouldn't answer the nationality question, he kept giving me the company name! I can't believe that kits are all the way down to $80 that's un believeable...
Old Mar 1, 2009 | 07:38 PM
nfisher50's Avatar
Even if you push the reflector in for the bulb to fit flush in the housing, how did you wire it up. the only way I see this happening is to cut the back of the cover for the new seal to fit. Anyone have pictures?
Old Mar 2, 2009 | 06:29 AM
Jreed2008's Avatar
Yeah I kinda half azz that part because I just wanted them done so I did not even cut the cover I just stuck the little rubber plug in the housing that came with the Hids and pray that will keep out any moisture or water
Old Mar 2, 2009 | 08:46 AM
hi-tek22's Avatar
I didnt push anything out, I put the H3 bulbs in with no problem....Ive had the same setup for over 2 years
PH98I30
Jan 9, 2025 08:08 AM
JRod28
Dec 29, 2023 09:56 PM
mikekay
Aug 10, 2015 12:52 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
