weird noise from front left...
Old Mar 3, 2009 | 02:40 PM
Max00se's Avatar
i noticed that there is a humming comming from the front left tire. I let off the gas and it starts humming. I apply the brake and the noise goes away. Could this the a wheel balance issue because i look in the tire and the wheel weights are no longer stuck inside the rim? Anyone got any idea?
Old Mar 3, 2009 | 03:21 PM
maxipower's Avatar
no it s not the balance because the tire will vibrate or wiggle at high speeds,,what speed were you driving when the hum started,,,my idea is the hum may be the hub bearing,,
Old Mar 3, 2009 | 10:26 PM
blkAEmax82's Avatar
Glory Glory Man United
on the wheel bearing. You might want to jack up your car and pull on your rim left to right (pull from 3 and 9 location). If you have some play, that's a sign of a bad bearing.
Old Mar 3, 2009 | 10:45 PM
jowo9's Avatar
Ok,
this might sound a bit dumb, but I had the same problem a few weeks ago, and all it was was a loose wheel!!! most of the lug nuts were so loose that I could turn them with my fingers easily. Kinda scary.. so yeah, It would make the noise whenever i was coasting... if I braked or accelerated it would go away... just check?
pktaske
May 6, 2016 07:49 AM
dvcamp
Sep 18, 2015 10:17 AM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
