Ball Joints
Old Mar 10, 2009 | 11:09 PM
Dimashka's Avatar
Ball Joints
I went to the dealer to get my oil changed and to get my wheels balanced. He showed me later that my steering wheel shakes because one of the ball joints is broken.
has anybody used these or knows anything about these?
Would it be better for me to buy them from the dealer?
http://cgi.ebay.com/ebaymotors/Ball-...Q5fAccessories
Old Mar 10, 2009 | 11:25 PM
knight_yyz's Avatar
Toolie
buy moog ball joints, you don't have to replace the whole control arm
Old Mar 10, 2009 | 11:28 PM
Dimashka's Avatar
I was going to do it by my self and i thought it would be easier not to press in and out the bushings. Also, the price seems right. Can you tell me where I can buy those so I can take a look at what you are talking about.
Anybody else that might have had some experience with this set on ebay?
Thanks guys
Old Mar 10, 2009 | 11:37 PM
knight_yyz's Avatar
Toolie
The ball joints are easier to replace than the whole control arm. And the ebay control arms are not good quality. Buy some Moog brand ball joinst for about 50 bucks each and swap them out. Dealership doesn't sell them, they will tell you (lies) that the ball joints can't be replaced.
http://www.energysuspensionparts.com...od=MOOG-K90459
pmohr's Avatar
No more Maximas...
Thanks guys
There have been quite a few reports of bad LCAs from eBay, or the bushings/ball joints fail after a short period, or the hole for the sway bar end links are slightly larger than factory, causing noises.
It's possible to replace them without pressing them in and out, FWIW.
Old Mar 10, 2009 | 11:49 PM
nismology's Avatar
Truth. Without even removing the arm..
Old Mar 10, 2009 | 11:52 PM
pmohr's Avatar
No more Maximas...
Flat rate method FTW
Old Mar 11, 2009 | 05:04 AM
Parthur's Avatar
Interesting!! how do you do that, I am thinking that I need to do mine, I want to get the moog ones.
Actually I am thinking on doing the whole suspension I got a quick question too; Do i really need to chage the springs?? Got a 2000 SE and will get tokico blues, do not want to lower the car, so I need new springs? and beside ball joints, bushings and sway bar..... what else should I get???
Old Mar 11, 2009 | 05:09 AM
fflint_18's Avatar
definitely go with the Moog's. And most of them have grease fittings (not sure abiut teh Max's) so you can take care of them and they will last much longer.
Good quality stuff.
Old Mar 11, 2009 | 11:18 AM
knight_yyz's Avatar
Toolie
to remove the ball joint, there is a spring clip which needs to be removed, then just pound it out with a hammer.
Old Mar 11, 2009 | 01:31 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
whuzzat
Old Mar 11, 2009 | 09:06 PM
MaxSE2001's Avatar
i bought those control arms (only both sides) from that same seller about 4 months ago and havent had a problem yet. fitment was good and installation took me for the first side about hour than second side once i knew steps about 30 mins
Old Mar 13, 2009 | 11:05 AM
GigEmAgs07's Avatar
your ***** have joints?!
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
ivorton23
Sep 26, 2015 09:47 AM
