gap between headlights/bumper 2002
Old Mar 19, 2009 | 06:44 PM
LoStWiThOuTaMAX's Avatar
I recently purchased 2001 Ann.Ed headlights, when installing on my 2002 maxima i have a nice(Horriable) GAP between the bumper and headlights..Is there anything i can do to fill this gap (without changing bumper to 2001) Please any ideas
Old Mar 19, 2009 | 07:15 PM
Progress's Avatar
It's business time.
Why would you downgrade HIDs to halogens?
Old Mar 19, 2009 | 07:22 PM
dwade27's Avatar
^^ my thoughts exactly
Old Mar 19, 2009 | 07:25 PM
maxfever1987's Avatar
maybe becuz he doesnt want his hids stolen, if he uses the ae headligths no one will be able to tell he has hids in there, im guessing thats y
Old Mar 19, 2009 | 07:29 PM
nsnrider's Avatar
see if you can adjust the bumper support brackets by bringing them a bit higher, maybe add some washers or spacers. Can you take a pic of how bad it looks?
Old Mar 19, 2009 | 07:38 PM
denny_1986's Avatar
just so you know 01s themselves have a little gap under the headlights (at least i do). Have to see pics to verify if its the same amount or more on an 02..
Old Mar 19, 2009 | 07:46 PM
Shinjiduo's Avatar
Maxima Grounding Kit Spec
I believe the headlight support clips for the 00 - 01 headlights and the 02 - 03 headlights are different. I know that the 02 lights did not fit right in my 00 until I changed the clips.
Old Mar 19, 2009 | 07:58 PM
Progress's Avatar
It's business time.
Do the '01 headlights have that rubber insulation strip thing on the top of the headlamp like the '00s do?
Old Mar 19, 2009 | 10:57 PM
unrealii's Avatar
My 01 does not. That rubber insulation may have been added per tsb: http://maxima.theowensfamily.com/tsb/NTB02-005.pdf
Old Mar 20, 2009 | 06:34 AM
Progress's Avatar
It's business time.
Does anyone else find that odd? What change (beside that rubber thing) did they make between '00 and '01 and why?
Old Mar 20, 2009 | 06:39 AM
denny_1986's Avatar
the hood shakes when driving that's why they added the rubber seal over the headlights as per the tsb...i want to get that done too.....waiting for spring break
Old Mar 20, 2009 | 06:43 AM
Wow....You hit the nail on the head.....Sharp....HIDs are much brighter with these housings....NOW can someone help me with my delemma
Old Mar 20, 2009 | 06:45 AM
The change was not made from 2000 to 2001....but 2001 to 2002...2002 lenses are about 3/4 inch wider which leaves me with a HORRIABLE gap
Old Mar 20, 2009 | 06:51 AM
It's sad to say but i might just put a 2000-01 front bumper cover (will this go righ on..anybody know) since my bumper was hit and repaired....Sad because i really like the 02-03 bumer much more (nicer grille)
Old Mar 20, 2009 | 08:07 AM
Progress's Avatar
It's business time.
My question is why do '01s have the problem but '00s don't? Why did they sell '01s without the seal?
Old Mar 20, 2009 | 08:41 PM
zero2sixtyZ's Avatar
You embarrass me.
Wrong. HIDs are not brighter with halogen housings, they just cause more glare. It's also illegal to do so, and gives you less usable light on the ground. You blind oncoming traffic and can't see where you are going. 00-01 housings, stick to halogens if not doing a projector retrofit.
Old Mar 20, 2009 | 10:25 PM
showgun9's Avatar
Just stick to your 02 HID headlights. It's the best output you can get other than doing a projector retrofit. As mentioned earlier, putting HID's in the 01 AE headlights is a downgrade, not to mention illegal. Just get the housings painted black and they'll be better than the AE's. Plus you don't have to worry about the gap.
Old Mar 22, 2009 | 05:21 PM
The reason for the housing change is NOT for a different look or brightness....In NY they are still stealing these lights and tearing up the car while doing so. In some cases they will rip out the grill cut horn wires pop hood and steal the bumper and headlights......I have no time for that nonsense
Old Mar 22, 2009 | 05:44 PM
Progress's Avatar
It's business time.
I don't get it. How much money do they get for these? You can buy HID kits online for like $50.
Old Mar 23, 2009 | 01:36 PM
showgun9's Avatar
Ok, I got you. I didn't realize that this problem was still prevalent as the cost of HID technology has gone down considerably. But I suppose the value of OEM components remains high. GL with fixing the issue
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Marc2theMax
Sep 28, 2015 08:13 AM
