bad motor mount = hard getting into gear?
Old Mar 21, 2009 | 11:07 AM
Ahmad_1290's Avatar
Its real hard getting into gear sometimes when the cars not warmed up. Especially R and 1st. I was under my car the other day and noticed my rear motor mount was shot. Could that be my problem?
Old Mar 21, 2009 | 11:31 AM
pmohr's Avatar
No more Maximas...
No.
Has it always been like this?
What sort of gear oil do you have in there?
Old Mar 21, 2009 | 12:28 PM
HotshotVQ35's Avatar
check your hydraulic clutch Reservoir..see if there is any fluid in there
Old Mar 21, 2009 | 01:15 PM
Ahmad_1290's Avatar
its been like that since i bought last month, and the clutch fluid is full. I changed the gear oil to Redline MT-90. Drained it and put about 2.5qts in.
Old Mar 21, 2009 | 01:19 PM
pmohr's Avatar
No more Maximas...
You're pretty much looking at one of two things, gear oil being so thick in the morning that it's hard to get into gear, or the clutch isn't fully releasing.
So did it do it before you changed the gear oil, or after?
Ahmad_1290's Avatar
Sometimes in the mornings its so hard getting into reverse i have to take off the car, and start it in reverse.
Old Mar 21, 2009 | 01:21 PM
Ahmad_1290's Avatar
it did it before and after. I think it might the be clutch not fully releasing, how can that be fixed?
Old Mar 21, 2009 | 01:24 PM
pmohr's Avatar
No more Maximas...
First thing I would do is bleed the clutch, and put in new brake fluid. Seeing as it's temperature related, it could be the master or the slave.
If that didn't do the trick, adjust the pedal, but that's really just a temporary fix until you fix the problem.
Old Mar 21, 2009 | 01:49 PM
Ahmad_1290's Avatar
just tried bleeding it, didnt do anything. How do i adjust the pedal?
Old Mar 21, 2009 | 02:20 PM
Progress's Avatar
It's business time.
Old Mar 21, 2009 | 05:50 PM
Ahmad_1290's Avatar
Hey progress where did you find that link?
Old Mar 21, 2009 | 05:54 PM
pmohr's Avatar
No more Maximas...
That's the FSM, see my sig.
Old Mar 22, 2009 | 10:46 AM
Ahmad_1290's Avatar
I just adjusted it. It did the trick, thanks guys
Old Mar 22, 2009 | 11:24 AM
Progress's Avatar
It's business time.
Which nut/bolt did you adjust?
Old Mar 22, 2009 | 04:26 PM
Ahmad_1290's Avatar
The one in the back. Its weird now because it goes into gear smooth, and when i first did it it released off the ground. Now it doesn't.. it sometimes it randomly decides to
Old Mar 24, 2009 | 09:56 AM
Ahmad_1290's Avatar
Okay so the morning after I adjusted the pedal. It wouldn't go into gear. Right after i would adjust it it'd be fine.. If i drive it than park it, the next morning its back to square one.. or even worse.. I was looking at the transmission and saw this. Does this look right? Is that goldish bolt thing suppose to go straight in there? Heres a pic. If anyone with a HLSD transmission can look at theres and see if its the same. or even take a pic. That'll help
Thanks in advance
Old Mar 24, 2009 | 01:19 PM
Ahmad_1290's Avatar
anyone?
Old Mar 24, 2009 | 03:23 PM
4DSCDriver's Avatar
Thats odd. I've never seen a copper fitting over the slave cylinder pin. The pin can get sort of noisy so maybe that was there fix. Who knows, but from what I've seen, that copper piece shouldn't be there...at least on the 5sp. Not sure about the 6sp.
Old Mar 24, 2009 | 03:33 PM
Ahmad_1290's Avatar
anyone with a 6spd got a pic?
Old Mar 24, 2009 | 04:36 PM
pmohr's Avatar
No more Maximas...
The copper piece shouldn't be there.
Old Mar 24, 2009 | 05:21 PM
2slow's Avatar
Ummm.....replace the slave cylinder?
Old Mar 24, 2009 | 06:04 PM
datdude20's Avatar
might just need to let the car warm up....lol........
Old Mar 24, 2009 | 08:30 PM
Ahmad_1290's Avatar
Whats suppose to go there? Could this be the problem?
Old Mar 24, 2009 | 08:35 PM
pmohr's Avatar
No more Maximas...
Nothing should be there, the slave cylinder piston should directly contact the clutch fork.
It's not likely the problem, it's actually giving you a bit more throw to disengage the clutch.
Old Mar 25, 2009 | 12:51 PM
Ahmad_1290's Avatar
I've got a new issue now.. The clutch pedal gets soft after highway driving and it engages right off the ground. A couple miles into city driving the pedal gets realll springy and engages real high, like right at the end.. is it the master cylinder thats gone bad?
Old Mar 28, 2009 | 10:30 PM
Ahmad_1290's Avatar
anyone?
Old Mar 31, 2009 | 10:34 AM
Ahmad_1290's Avatar
So should i replace the Slave cylinder or master cylinder?
Old Apr 1, 2009 | 03:06 PM
nicks79's Avatar
2.5 quarts is not enough, if you drained all, it takes about 4.5qts.
Old Apr 1, 2009 | 03:09 PM
pmohr's Avatar
No more Maximas...
The FSM and the dozen times I've refilled the RS6F51 say different.
Are you referring to the 5MT?
Old Apr 1, 2009 | 04:17 PM
nicks79's Avatar
yes, 5MT..
Old Apr 1, 2009 | 04:19 PM
pmohr's Avatar
No more Maximas...
yes, 5MT..
He has an A33B (and has mentioned HLSD and 6MT a few times in this thread), hence a 6MT.
Factory fill is 2.3 liters, ~2.5 quarts.
Old Apr 1, 2009 | 06:20 PM
Ahmad_1290's Avatar
anyways, whats it mean when the pedal firmness changes after driving? city driving the pedal gets real hard and engages high. After a highway drive it gets mushy and engages low.
Old Apr 1, 2009 | 06:21 PM
pmohr's Avatar
No more Maximas...
I would change out the master.
Old Apr 1, 2009 | 06:24 PM
Ahmad_1290's Avatar
Is it safe to get one from the local auto parts store? They've got it for $70
Old Apr 1, 2009 | 06:28 PM
pmohr's Avatar
No more Maximas...
Yes, they should work just fine.
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
homeyclaus
Sep 3, 2015 06:15 PM
Rage Maximus
Sep 3, 2015 12:26 PM
george__
Aug 18, 2015 07:06 PM
