erased code never came back...nothing wrong?
Old Mar 23, 2009 | 10:27 AM
2damax's Avatar
p1147 came on. erased it about 2 weeks ago and it never came back on. Autozone gave me the wrong sensor so should I go get my money back or get the right sensor? car should idle at 750 but does it at 600 often and my gas has not gone down that much.
Old Mar 23, 2009 | 12:05 PM
oldngivout's Avatar
Willing to learn
Sure, get your money back on the wrong sensor, but hold on to that refund. You will be spending it on the correct sensor when that light reappears.
And it will. Oxygen sensors are known for this.
Old Mar 23, 2009 | 12:58 PM
Scottwax's Avatar
That's Mr. Detail to you
Exactly right. I had a P0037 (low voltage bank 1 rear O2) come on back in September. Played the reset game for a couple weeks, then it went out and stayed out. Until last month that is and it comes back on within about 10 miles of resetting it.
Old Mar 23, 2009 | 04:41 PM
Blitzfist's Avatar
probably will come back but there is a possability that it was just a ghost code if it only came on once. I would return the sensor and then buy the right one if the light comes back on.
Old Mar 23, 2009 | 05:28 PM
2damax's Avatar
thanks for the help. Just got my money back
Old Mar 23, 2009 | 09:17 PM
rroderiques77's Avatar
Demodded and Forgotten
I recommend replacing both downstreams.
Old Mar 23, 2009 | 09:34 PM
2damax's Avatar
yeah you said that in another thread. I think the manual says to do it too. I figure its because when one goes the other is not far behind. I rather wait until the other one goes...
Old Mar 24, 2009 | 07:47 AM
Scottwax's Avatar
Actually, it is because there is an ECU reflash that goes along with the replacement of both sensors. Not sure if the reflash works properly unless you replace both.
Old Mar 24, 2009 | 10:37 AM
2damax's Avatar
Alright you guys win. When I do it I'll do B1S2 and B2S2 and leave the negative out for a while....btw...nissan wanted $600 to do that
Old Mar 24, 2009 | 02:30 PM
Scottwax's Avatar
Not reset, REFLASH. There is a TSB out on this. Replace both rear O2s than get an ECU program reflash which updates the software. Kind of like when you get a window's update.
Old Mar 24, 2009 | 03:19 PM
4DSCDriver's Avatar
The previous owner of my car replaced both sensors, but did not get the reflash. After a couple hundred miles, the O2 code popped and would't go away. I went to Nissan, payed $100 for the reflash and haven't had a problem since.
Old Mar 24, 2009 | 05:46 PM
2damax's Avatar
very helpful. thanks a lot guys
maxinout93
Oct 31, 2015 02:04 AM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
