P0430 code aka CAT needs to be replaced
Old Mar 25, 2009 | 05:48 PM
Max_Man116's Avatar
ive got the p0430 code and my car stinks like **** lol so i know my cat needs to be replaced but my question is can i replace it wit a aftermarket header to solve the problem?
Old Mar 25, 2009 | 08:51 PM
jvienneau's Avatar
If your exhaust smells there's probably something else wrong.
Scottwax's Avatar
That's Mr. Detail to you
You will have to run O2 sims if you eliminate the precats by installing headers to pass emission testing.
Old Mar 25, 2009 | 08:53 PM
nsnrider's Avatar
I don't see a cat. in that pic, oh wait, thats because there is none, therefore you 'll need sims as mentioned above.
Old Mar 26, 2009 | 06:26 AM
Max_Man116's Avatar
ok thanks guys so headers and a o2 sim is the way to go
Old Mar 26, 2009 | 06:31 AM
2damax's Avatar
http://www.nicoclub.com/Matt/p0430.pdf
check that out. Maybe some plastic is melted to the exhaust?? lol
Old Mar 26, 2009 | 06:42 AM
Max_Man116's Avatar
lol nah i dont think thats it ...and im pretty sure it wont give me a p0430 ...i can also hear like a rattle when i accelerate
Old Apr 2, 2009 | 12:55 PM
Ahmad_1290's Avatar
i had that rattle. Until i gutted my precats
Old Apr 2, 2009 | 05:56 PM
Max_Man116's Avatar
how did u gut ur precats ???
Old Apr 2, 2009 | 06:08 PM
klemenz's Avatar
I'm planning on getting the cattman setup but I have to fix a couple other things first..
Old Apr 3, 2009 | 11:45 AM
Rico456's Avatar
what cat is needed to be changed to eliminate a p0430 code, pricing and where to get a reasonable priced one would be helpful
Old Apr 3, 2009 | 11:53 AM
jvienneau's Avatar
You should replace both downstream O2 sensors and have the ECM updated before you buy a CAT.
Old Apr 5, 2009 | 04:29 PM
gpmax's Avatar
Any links on installs of the o2 sims? Do these this go in like the defoulers? Nevermind-found Puppet's old thread (search actually worked ) http://forums.maxima.org/5th-generat...tallation.html
Old Apr 5, 2009 | 06:46 PM
Scottwax's Avatar
Apparently, non-foulers work. I might just gut my precats and screw some non-foulers in and see how that works.
Old Apr 6, 2009 | 09:30 AM
gpmax's Avatar
I think I am going that route also I keep getting 0420 and 0430 just in time for inspection...
Old Apr 6, 2009 | 12:49 PM
Kevin319's Avatar
I passed inspection with a bottle of "Catalytic Converter" at pepboys. It turns cel off from a couple days to couple of weeks.
Old Apr 6, 2009 | 06:44 PM
Scottwax's Avatar
I squeaked by my inspection, replaced my rear bank 1 O2 and a couple days later my car popped a stoner code (P0420). Reset the computer and drove it around long enough to have 6 monitors ready, the only one not ready was the catalyst but you can have 1 not ready and still pass...and pass I did. Just for fun, I checked after lunch (about an hour after I passed my inspection) to see if all were ready yet-showed 1 not ready (catalyst) and a pending P0420 code.
Next day the SES light came on for the P0420, reset it and a week later it popped up again. Now it is a few days later, all monitors ready and no codes. Ugh.
Old Apr 7, 2009 | 08:11 AM
gpmax's Avatar
Oh boy...I think I am going to rip off those crap cats and just go with a header and a decent hi flow cat. Good justification for the purchase don't you think? Wheezy needs more power anyways- some lady in a G6 pontiac wouldn't let me pass her getting on the freeway...I had to acknowledge defeat.
Old Apr 9, 2009 | 03:00 AM
nystateofmind308's Avatar
I have the p0430 code right now, and apperently its the Bank 2 Downstream sensor thats faulty. I was thinkin of just replacing all the damn o2s sensors and then clearing the SES light and taking it from there. I am also gettin really ****ty gas mileage...20 bucks lasts me 2 days with only driving 130 miles, its ridiculous.
Old Apr 9, 2009 | 06:44 AM
gpmax's Avatar
My mileage has taken a dump too. Terrible.
Old Apr 9, 2009 | 03:28 PM
Scottwax's Avatar
If your mileage has taken a huge dump, odds are it is the pre-cat and not the O2. All the rear O2 does is monitor the pre-cat function.
The FSM lists the following possible causes for P0420/0430 codes:
1. Warm up three way catalyst
2. Exhaust tube
3. Intake air leaks
4. Injectors
5. Injector leaks
6. Spark plugs
7. Improper ignition timing
Improper ignition timing would definitely affect your mileage, so would bad plugs, in addition to a clogged cat.
JRod28
Dec 29, 2023 09:56 PM
kjlouis
Nov 24, 2018 06:09 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxima297
Aug 3, 2015 12:50 PM
