4th gen brakes= fifth gen?
Hi guys!
Just picked up an 02 SE last Friday and I'm loving it so far especially given that my other ride is a 4th gen! Anyway, I need to change the front rotors and pads on the 02 and I went on Ebay and most of the vendors have the 99-03 lumped together and this got me thinking- I have some front rotors and pads's that I had bought for my 4th gen but it turned out I didnt need them. Naturally, the question is, will these fit the 02? If they do it saves me about $90 bucks in parts.
I remember seeing something about the brakes getting updated on the 04's on but I'm thinking, the 02's a heavier car, no way they'd have the same brakes. And yes, i've searched already.
-4th gen rotors and 5th gen 00-01 rotors are 11" and exactly the same
-4th gen and 5th gen 00-01 (bigger piston) calipers are interchangable, but not the same and you would have to get the corresponding pads for each caliper
-5.5gen calipers fit on the 4th gen and 5th gen 00-01 with minor modification but no brackets needed.
-5.5gen rotors are 11.5"
-you can not use 4th gen/5th gen 00-01 calipers on a 5.5 because of the larger bolt holes.
What I would really like to see is someone get the g37 front calipers and rotors with brackets ($1025), 14" rotors and 4 piston calipers :yum: (and no you can't use the rears...don't ask)
http://g35driver.com/forums/brakes/2...-06-sedan.html
Thanks Drunkie. Ya, I knew there was a 5th gen connection somewhere but wasnt sure. Like I'd mentioned, 02 feels like a much heavier car than the 4th which is what made me skeptical.
on the g37 caliper's!! For anyone else wondering, there's actually a link on the interchangeability under the Advanced Suspension/ Braking forum but its down at the moment. I think Irish or someone is trying to get those links back up. That should have a ton more info. HERE:
http://forums.maxima.org/advanced-su...ion-links.html
I know this is old but nearly all of that info is wrong. 95-99 and 00-01 rotors are not the same. Same diameter yes, but 00-01 are thicker. Pads are the same fron 95-03. Im pretty sure the pistons are the same diameter from 95-01, but the caliper and torque member are thicker on the 00-01 to clear thicker rotor. 00-01 tourque members also use the larger bolts like the later VQ35 cars. So the 02-03 caliper would need the matching torque member and rotor to install on the VQ30 cars.
MAXSE5SPD
Sep 17, 2022 04:00 AM
