Headlight Restoration Kit?
Old Apr 2, 2009 | 04:04 PM
Country24's Avatar
I have a 01 max and my headlights were yellowish and hazy. I used a healight restoration kit and them came out nice but when i turn my headlights on it is still kinda hazy? What could i do to fix it?
Old Apr 2, 2009 | 04:06 PM
Maybe wetsand? You can also try that kit again.
Old Apr 2, 2009 | 04:18 PM
Country24's Avatar
did that, is there any kind of solution i can use?
Old Apr 2, 2009 | 04:21 PM
Personally, I use Pledge (yes the wood cleaner). Use it on the headlights, tails, etc. I have no haze or fog on my headlights.
Old Apr 2, 2009 | 04:48 PM
Country24's Avatar
really that will attract dirt but i will try that.
Old Apr 2, 2009 | 04:55 PM
denny_1986's Avatar
brasso
http://forums.maxima.org/detailing/5...ning-pics.html
Old Apr 2, 2009 | 05:01 PM
Spray it on a rag and apply it, let it sit for a minute or 2, then buff it out as best as you can.
Old Apr 2, 2009 | 05:08 PM
maxman7's Avatar
You guys are probably not see this but just in case, I can promise Ya mothers mag and alluminum polish ( in the jar) does better than any of the previous products that were posted, I have tryed them all. It really works best to hit it with mothers first with a small (slow) buffer and then go over by hand with Flitz it is less gritty. I have been polishing with mothers for years and it is the best and cheap too! This stuff will remove scratches if Ya got the patience and elbow grease to do it. I just payed 15 dollars for some high dollar headlamp polish and it only removed a little oxidation the trusty ole mothers removed rock chips and scrathes I was pretty proud of my 45 min. restoration. Dont expect this stuff to remove deep scratches in two or three rubs but if You have the time and dont buff through the lens first you will get that bugger inventually. PS. If using a buffer be very careful not to burn the lens stop and let the plastic harden or cool frequently. maxman7
Old Apr 2, 2009 | 10:45 PM
4DSCDriver's Avatar
Mine were pretty oxodized when I got the car last year. I spent a few minutes buffing with Brasso and got most of it out. Now, I use Brasso once a month and follow with a couple coates of wax.
And yes, the Mothers mag polish works wonders as well...it;s just alot mroe expensive than Brasso.
Old Apr 2, 2009 | 10:54 PM
choiiiiiiiiiii's Avatar
meguir
Old Apr 3, 2009 | 04:12 AM
2slow's Avatar
3M Restoration kit. $16.
Assuming the problem is on the outside of the lens, of course.
Old Apr 8, 2009 | 04:10 PM
bs02maxima's Avatar
mine got cleared up but at nite with the lighs on the hole outter ring looks horibble yellow but during the day there mint looking..i used meguires plastix on the inside and out of the lens ..came out mint ..but horrible yellow at nite
Old Apr 8, 2009 | 04:40 PM
TheOnlyMax88's Avatar
Brasso does the trick, rub it in circles rinse then use wax after, i dont and it still comes out nice
Old Apr 8, 2009 | 05:02 PM
anomaly117's Avatar
you got a 96, so you have glass. do you think the pledge would work the same on plastic?
Old Apr 8, 2009 | 06:22 PM
Works on my 5.5 gen as well FYI (which has plastic lenses).
Old Apr 8, 2009 | 08:41 PM
phxgold's Avatar
http://tinyurl.com/dd4hz8
Old Apr 11, 2009 | 05:39 PM
kship's Avatar
brasso baby! worked like a champ!
09maxshawn11
Sep 30, 2015 10:28 AM
Pied
Sep 26, 2015 03:29 PM
Noela
Sep 26, 2015 08:22 AM
