02 maxima high idle...
Old Apr 3, 2009 | 07:40 PM
Nevermore's Avatar
well after changing my spark plugs on my 2002 maxima, the car started idling a little higher than normal and surges a bit after a lil acceleration(very minimal) but feels fine going at high speeds and accelerating quickly.
what is the normal idle speed anyway? any help solutions? thanks guys
Old Apr 3, 2009 | 11:12 PM
Nevermore's Avatar
anyone?
Old Apr 4, 2009 | 12:40 AM
boris's Avatar
With MT: 625 +/-50rpm; With AT: 675 +/-50rpm. You probably need to perform the following procedures:
http://forums.nicoclub.com/zeropost?cmd=tshow&id=299577 Always worked on my car.
Old Apr 4, 2009 | 09:32 AM
joeltender's Avatar
If you have any codes eg.p0507 and so on, get them cleared first. The idle relearn procedure should work after that.
Old Apr 5, 2009 | 08:45 PM
Unklejoe's Avatar
Also make sure you're using the proper plugs. Go with NGK. Not sure of the model number, do a quick search.
Old Apr 6, 2009 | 05:59 PM
Nevermore's Avatar
yeah I put in brand new NGK lasers ( was going to do Iridiums but they were sold out)
Ill try the suggestions. thanks guys
Old Apr 9, 2009 | 10:33 AM
cpuguy06's Avatar
Same issue and code P0507 after having the dealer change plugs.
Old Apr 9, 2009 | 11:00 AM
nissandrvr98's Avatar
early MAF failure or possible coil issues?
Old Apr 9, 2009 | 06:13 PM
2K2Beast's Avatar
not tryin to hijack.......but i have very very similar issue
http://forums.maxima.org/5th-generat...lve-cover.html
someone mentioned getting new gaskets and trying to seal it down with rtv sealant and seeing if that takes care of it.......
that what im going to try next because i have checked and double checked all of my hose and contact points and no air leaks....
Old Apr 9, 2009 | 08:21 PM
joeltender's Avatar
Try checking your coils, performing relearn procedures to start with
Old Apr 9, 2009 | 10:27 PM
STILLENGLE's Avatar
check your alternator.
Smiley101
Aug 1, 2024 08:02 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
acw
Aug 13, 2015 12:50 AM
Flores94
Aug 11, 2015 12:53 PM
MikesChevelle
Aug 6, 2015 11:36 AM
