suspension help
Old Apr 11, 2009 | 12:02 AM
navigator82's Avatar
suspension help
the history: i have a 2002 maxims SE is mostly stock working in perfomance. and i install a new springs and struts, shocks in the car. but the front left side is making a clungking noise when turnig the wheel to any direction and i dont have the manual for the torque spec in the bolts ,nots and im loocking for solutions if someone can helpme thanks
Old Apr 11, 2009 | 12:04 AM
what you think guy it could be the problem for the noise sorry this is the first question thaks
Old Apr 11, 2009 | 04:39 AM
fflint_18's Avatar
Did you install new springs and struts??
Or do you want to??
Clunking noise could be a number of things. Ball joints, strut mounts, etc.
There are plenty of manuals online for you. Just search n FSM.
Old Apr 11, 2009 | 05:48 AM
witeonblakmax's Avatar
There is a black piece that is under the strut mount it fits on the top of the spring.. Did you put that back on?
Old Apr 11, 2009 | 06:46 AM
CMax03's Avatar
What kind of struts did you install? If they are regular non-adjustable style then please torque the upper strut rod nut to 44-65 ft-lbs, the strut mount bracket (3 nuts) 32-38 ft-lbs. If they're Tokico Illuminas or AGX read your installation instruction the torque is less than the factory struts upper strut rod nuts! Also check that your coil isolators on the top and bottom of the spring or installed, Check that the round cutout on the upper strut mount is facing out, and check the your coil spring is set in it's upper and lower spring perch properly! GL
Old Apr 11, 2009 | 02:44 PM
i did install new struts kyb gr'2 and progress springs
Old Apr 12, 2009 | 01:51 AM
CMax03's Avatar
Did you recheck everything including the torque of your fasteners?
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
