9003 Lightbulb question
Old Apr 13, 2009 | 08:59 PM
00MAXI's Avatar
So I gotta burnt out headlight (OEM) I remember putting in Silverstars but they burnt out after 6 months and then I threw the OEMs back in and one went down today.
So anyone have experience with the Sylvania Xtravision bulbs? I will never purchase a Silverstar again. Those Xtravision "seem" to be brighter and not burn out as fast. Any suggestions or thoughts? Oh I won't be doing HIDs on my 199k 00' Max with a dented bumper lol.
Old Apr 13, 2009 | 09:13 PM
mannetti21's Avatar
If I am not mistaken, the Xtravision and Silverstars produce comparable amounts of light, but the XtraVision light is not the typical "white" light that most are looking for.
I feel your pain with replacing Silverstars every 6months or so, but I would recommend you try the Silverstar Ultra...these are supposed to last 30% longer than the regular silverstars and they will still give you that nice, crisp white light.
Also, when you are changing any headlight bulb, its a good idea to use a papertowel or something else so that you dont touch the bulb. This can decrease the life of the bulb...I currently have one bulb that is about 40% brighter than the other bulb, and I distinctly remember accidently touching the bulb when I installed.
Old Apr 13, 2009 | 09:36 PM
maxdriver10's Avatar
You are needing to replace the bulbs every 6 months because you're touching the actual bulb with your fingers which transfers oils to the bulb and causes it to burn out faster. Wear gloves and don't hold it by the glass
Old Apr 13, 2009 | 09:38 PM
and the ultravisions are extremely white and bright for non-hids
Old Apr 14, 2009 | 08:05 AM
Rion's Avatar
i need help on this one i have a 00 nissan maxima and my headlights and fog lights wont come on but when i turn the switch the park light is the only thing that comes on the dash light on the inside are ok and i check all the fuse under the hood and dash and i check the relays by switch them to the park light relay and the are fine but there is no click nose come from them when i put them back in the oringinal place can the switch be bad and still turn on the park light
Old Apr 14, 2009 | 08:33 AM
mannetti21's Avatar
that was tough to understand due to some key punctuation, or lackthereof...and I'm just throwing this out there, but have you checked the bulbs themselves? How about the highbeams?
Old Apr 14, 2009 | 09:44 AM
Rion's Avatar
no highbeams and the bulbs are oka i can jump the relay and the lights comes on but the switch will not turn it off or on if i jump it
Old Apr 14, 2009 | 01:38 PM
sounds like a burnt wire?
Old Apr 14, 2009 | 02:08 PM
RA121625's Avatar
I believe it actually states on the back of the package itself that the higher output bulbs have a decreased life.
Dunno about you guys but up here in Canada, all bulbs bought at Canadian tire come with a one year warranty, meaning that if they burn out within a year, they will replace it on the spot for free so you can get a lifetime supply of bulbs from them. You should check to see if the automotive stores give any warranty on the bulbs, I'm pretty sure they should.
Old Apr 14, 2009 | 07:52 PM
asianstyle's Avatar
I just put in some silverstar ultras and yes I would recommend them also.
Old Apr 14, 2009 | 09:01 PM
It also says to not handle the bulbs directly (glass part) as it will decrease the bulbs life...but yes higher output bulbs don't last as long, still 6 months is a very short lifespan for light bulbs, regardless of output...also I don't think autozone or advanced auto has a warranty on headlights.
Old Apr 15, 2009 | 03:43 PM
00MAXI's Avatar
Well actually I didn't touch the silverstars with my hands. You can easily install bulbs without ever touching the glass portion like I just did with that Xtravision by holding the bottom where the prongs stick out. Anyway, speaking of Silverstars the damn things burnt out quick and one of them melted my left headlight plug connector back in the day. So I had to buy some $18 thing at the dealer then switch back to stock. They were 55watts tooooo!
I am aware that the new Silverstar "ULTRAs" are much better
Old Apr 15, 2009 | 04:21 PM
my ultras have been in for a year with no problems...must have improved the quality
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
