suspension tread
Apr 16, 2009 | 09:36 PM
imsorry to put these post again if exist but i have a concern about my suspension an i dont find any answer.........the problem is in the rear shock is make a noise every time it hit a pothole or uneven surfase i jus put new shocks and lowered springs i check the bushings and i dont know what else to do please help
Apr 16, 2009 | 10:16 PM
Quote: imsorry to put these post again if exist but i have a concern about my suspension an i dont find any answer.........the problem is in the rear shock is make a noise every time it hit a pothole or uneven surfase i jus put new shocks and lowered springs i check the bushings and i dont know what else to do please help
Apr 16, 2009 | 11:52 PM
Quote:
Apr 17, 2009 | 11:05 AM
Be more descriptive of your problem and make more sense when you explain it, or nobody is going to be able to help you.
Apr 17, 2009 | 11:09 AM
Did you/the installer trim the bump stops when you installed the springs and struts?
Apr 17, 2009 | 11:36 AM
Quote: Did you/the installer trim the bump stops when you installed the springs and struts?
+1 or do you have a rear sway bar?
