Making some much needed changes (G35 wheel restoration included)
Old Apr 29, 2009 | 10:00 PM
SEmy2K2go's Avatar
Go BUCKS!!!
I sold my 18" Enkei Rp02's to Gregg aka tripleGmax who installed him on his civic. I picked these up locally and all four of them had some form of curb rash or rock chips throughout the wheel. Two of the tires were damn near completely bald and someone decided to take a grinding wheel to the inside portion to remove the old weights.
During the scuffing up phase:
Here you can see where the repairs began on the damaged areas:
3 of them still have a few spots that I'm working on, but one is now primered and ready for paint. I will painting them to match the original color.
Along with installing the new wheels & tires, I will be doing quite a major install this Saturday with 3G's help installing a new full suspension since my current setup has at least 3 struts that are blown. This will be suspension setup #3 since I've owned the car and this time around I went with quality parts. I've also purchased new top hats, strut bearings/mounts as well as new front sway bar end links which will aid in keeping the car tracking better.
Tokico 5-way Illumina Struts / H&R Sport Springs
EDIT:
Some people on another forum were asking me what process I used to restore the wheels, so here it is in a nutshell. I will update as the project nears completion.
1) I used regular Bondo body filler to repair the curb damage and on the rock chips that were here and there on the wheel surfaces.
2) I used a variation of sand papers, starting with 60 to knock down the Bondo'd areas. I used 180, 220 & 400 to prep the wheel surface before primer. Used 1000 to quickly sand down the primer (sandable primer). Using 1000 & 1500 to wet sand the paint. Once I clear them, I'll probably use 1500 & 2000 grit to wet sand the clear. All sanding was by hand other than the lug nut holes where I used a dremel sanding wheel to get in the holes.
SEmy2K2go's Avatar
Go BUCKS!!!
On to the brakes:
I've gone through the OEM setup, a set of iRotors cross-drilled & slotted rotors as well as Brembo Blanks and they all last right around 30-35k miles before the shaking symptoms return. Knowing this, I decided to go to a larger setup in using the calipers & rotors from the 6th gen. Picked up a set of 2007 rotors and calipers from a MDeezy with only 18k miles. Had the rotors turned and have cleaned up the calipers prior to installing Saturday along with the suspension.
Caliper before:
After:
Pretty much my car looks like this with my kayak rack on top, so hopefully by the end of the weekend, it'll be looking, riding and braking much better. I'll keep it updated as progress continues.
Old Apr 29, 2009 | 10:33 PM
maximase86's Avatar
I love lamp.
Nice! BTW, whatever happen to the Axis rims you got from triple8sol?
S
Old Apr 29, 2009 | 10:44 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Sold those to Jason aka 00MaxSE who ended up selling them to PaulPearl or something like that.
Old Apr 29, 2009 | 11:35 PM
IHAVEA2KMAXIMA's Avatar
That's a good change.
Old Apr 30, 2009 | 01:57 AM
DrunkieTheBear's Avatar
Turbo'd Saab
Nice work so far.
I wish I had done the Illumina/HR setup intially, the eibachs really are a rough ride
Old Apr 30, 2009 | 04:28 AM
pbn85's Avatar
Nice work so far.
i had the illumina/h&r setup, bought new, still was very rough even on the softer settings. I got rid of it soon after. I cant imagine eibachs being much worse in the comfort section. My tein SS have been by far the most comfy setup by far. Atleast the H&R/illumina setup handled nice
Old Apr 30, 2009 | 07:14 AM
n3985's Avatar
大陆弟弟
Sounds like fun weekend to come
What pads are you going to use? If you haven't bought any steer away from Axxis, yes they don't dust much but their bite is pitiful compared to HPS when hot.
Old Apr 30, 2009 | 07:34 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I'm on the H&R / Illumina setup now, rides quite nicely.
Looks as though you and I are in the same boat, I've got hella maintenance to do in a few weeks as well. Looks good, Tim.
Old Apr 30, 2009 | 07:39 AM
Ahmad_1290's Avatar
I need to refinish my wheels, but i don't think i'm going with the same color
Old Apr 30, 2009 | 08:35 AM
Deckdout2's Avatar
Play with my balls
Nice work Tim! You're going to like everything about your new setup.
Old Apr 30, 2009 | 08:46 AM
Progress's Avatar
It's business time.
Will your winter steelies clear the 6th gen brakes?
Old Apr 30, 2009 | 08:59 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
How are you fixing your rims, what products r u using? Does anyone knows where to find a matching or close color for the G35's.. I have to do the same with my G35 ones... too many scratches.... nice set up going to your car... goos luck
Old Apr 30, 2009 | 09:16 AM
mist max2000's Avatar
Old Apr 30, 2009 | 12:30 PM
SEmy2K2go's Avatar
Go BUCKS!!!
No, 17" wheels barely clear the calipers, so my steelies/blizzaks will be up for sale before long and I'm shopping for 18" wheels with some winter tires.
Old Apr 30, 2009 | 02:55 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Making some progress on the wheels.
First coat:
Worked on the other three while the first one is drying. There was a bit of damage in the lug holes as well.
Trusty DeWalt with dremel attachment
Old Apr 30, 2009 | 02:56 PM
SEmy2K2go's Avatar
Go BUCKS!!!
2nd Coat:
3rd Coat:
Old Apr 30, 2009 | 02:58 PM
00MaxSE's Avatar
Pointy Elbows
Old Apr 30, 2009 | 04:18 PM
maxima dude's Avatar
niceee
Old Apr 30, 2009 | 05:36 PM
nismowolfe's Avatar
cant wait to see finished product looks awesome.
Old Apr 30, 2009 | 06:55 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Just a few more pics.
Old Apr 30, 2009 | 07:03 PM
00MaxSE's Avatar
Pointy Elbows
nice job!
Old Apr 30, 2009 | 07:08 PM
Puppetmaster's Avatar
You want to recondition my rims, Timmah?
Old Apr 30, 2009 | 07:20 PM
zero2sixtyZ's Avatar
You embarrass me.
What did you use to fill the spots with?
Old Apr 30, 2009 | 07:39 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Sure, I'd be happy to. When you coming to town?
Old May 1, 2009 | 02:15 AM
PhalC1's Avatar
This has inspired me to fix and recoat my wheels tomorrow lol
Old May 1, 2009 | 06:42 AM
Progress's Avatar
It's business time.
Now make it shiny!
Old May 1, 2009 | 06:46 AM
Come to think of it, I don't know that it is ever safe for someone from "that school up north" to come into your town. Ever.
Old May 1, 2009 | 06:47 AM
Progress's Avatar
It's business time.
OMG fight!
Old May 1, 2009 | 09:27 AM
00MaxSE's Avatar
Pointy Elbows
Old May 1, 2009 | 09:34 AM
danger300z's Avatar
what is the jb weld for?
Old May 1, 2009 | 09:52 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I thought about using that first to repair the damage before I found that using the Bondo would do the same job.
Old May 1, 2009 | 09:57 AM
Jeff92se's Avatar
I'm needing a caw
Looks fuzzy
Old May 1, 2009 | 10:09 AM
MROTH's Avatar
just did the same process to my g35 spokes, should have some pictures posted soon. went with the "bronze" color...
Old May 1, 2009 | 10:11 AM
djfrestyl's Avatar
Suspension Yoda
Nice job Tim. It seems many of us 5th gen owners are entering that second stage of mass maintenance that is required at the 125k-150k mark. My laundry list grows every week or so.
Old May 1, 2009 | 11:07 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Now make it shiny!
Originally Posted by Jeff92se
Looks fuzzy
I'm working on it. Needs a few more coats, wet sanded, then cleared.
Agreed. Coming soon is the plug/coil change. I also have a REALLY rusted fuel filler neck which has been throwing evap codes for a while. I have a new neck to install, just have to find time to do it.
118k and still going strong though. Figure that's why you hold on to a car with no payments, so you can invest that money into upkeep and repairs
Old May 1, 2009 | 01:00 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Sorry, I missed this one.
Not sure which I'm going to use, but I've had pretty good luck with OEM pads. I may just go that route.
Old May 1, 2009 | 02:44 PM
00MaxSE's Avatar
Pointy Elbows
Get some ceramic pads.
Old May 1, 2009 | 06:18 PM
everything looks good....
..time to get NWP spacers!!
Old May 8, 2009 | 01:21 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Now that the suspension is done, I can get back to work on the wheels. The other 3 are finally done with touch-ups and I have moved on to the primer coats.
