HELP NO CRUISE CONTROL
Old May 8, 2009 | 03:31 PM
williamgd2's Avatar
It just started today,I hit the cruise on button and the first light comes on.I hit the cruise engage button no cruise control but a flashing second cruise control light.Any and all help is greatly appriciated,I do all highway and like my cruise control.
Old May 9, 2009 | 10:59 AM
williamgd2's Avatar
No one has any ideas?The flashing light I get is the cruise set light.
Old May 9, 2009 | 11:48 AM
williamgd2's Avatar
I fixed it.Took out LED tail and brake bulbs and put old ones in.
Old Jun 8, 2009 | 11:57 PM
rcjunkie's Avatar
I have no cruise either but my 02 SE is bone stock. It's a daily driver. I have the same symptoms that you posted. Any idea of what could be causing the cruise not to work?
Old Jun 9, 2009 | 05:57 PM
pmohr's Avatar
No more Maximas...
It could be a hundred things.
Does the cruise light blink when you try to use it?
Old Jun 10, 2009 | 05:45 PM
scottygill's Avatar
Go to www.superbrightleds.com and get the 6ohm loaders. Their prices are great, they send you directions and even the clips to tap into without having to cut wires. Did you have an indicator light on your dash indicating that there is a problem with your lights? I think they fixed this cruise control problem on the 5.5 gen. I got my leds in recently and have an indicator light on needing the resistor install, however my cruise is still working.
Anyone else agree that the 6ohm loader/resistor will solve his problem and allow him to put his LEDS back in?
Old Jun 22, 2009 | 11:16 PM
rcjunkie's Avatar
The "cruise" light does not blink but the "set" light blinks.
Old Jun 23, 2009 | 02:33 PM
pmohr's Avatar
No more Maximas...
Is it throwing any codes related to the ASCD system?
I'd start by running through the diagnostics per the FSM.
Old Jun 23, 2009 | 02:41 PM
rcjunkie's Avatar
I'm actually headed out so I will try the cruise control and see if anything blinks a certain amount of times. I do have a check engine light that's been on for several years. The car has been running fine. I need to write the codes down the next time I get the oil change.
Old Jun 23, 2009 | 02:44 PM
pmohr's Avatar
No more Maximas...
And you've never got the codes pulled?
If you've got a CEL, the first thing you do is pull the codes before asking for help. There's no point in diagnosis if you ignore the primary means of identifying an issue.
Old Jul 8, 2009 | 04:10 AM
rcjunkie's Avatar
Thanks for the info. I'll go ahead and pull the codes. My 5.5 also has the AT light on the lower right panel flashing when I first turn on the car and then it disappears.
And it is confirmed that the SET light flashes when cruise is set.
Old Jul 8, 2009 | 11:26 AM
anomaly117's Avatar
thats exactly what i was gonna tell you to do. i had the same issue.
Old Jul 8, 2009 | 08:46 PM
Mu_036sp's Avatar
EVERYONE has that problem with LED? anyone know why?
Old Jul 8, 2009 | 10:44 PM
Unklejoe's Avatar
People have that problem most likely because the computer wont let the cruise control engage when there is a burnt out light.
The LED tail lights don't draw anywhere near the current that the stock bulbs do, so the ECU thinks that a bulb is burnt out, which is why you need the resistors to fool the ECU.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
