PAC SWI-X Write...do we have one here?
what kind of headunit do you have? I would get the one meant for it instead of the universal one, swi-ps/swi-jack. As far as the install goes, you can look up the install on PAC's website. I know you have to clip 2 wires and use 2 resistors connected to a brown/white wire on the stock harness.
here's the directions:
http://pac-audio.com/swixprogramming...ehicles&ID=261
The ironic and infurating thing is that I have hooked one of these up before in another members car using a link on here...thanks to IB, though, I cannot fawking find it.
One wire, eh? Two resistors?
If this is the case, then I think a xx-ohm and 1xx-ohm resistor are placed in series to the white wire of the PAC.
Sound right?
Well, I'll give it a shot. The directions completley contradict what's being called for [here], but if my memory serves me correctly, I had used resistors at the previously stated value last time.
Wish me luck, and thanks for your help.
post up how it turns out, I know on my SWI-PS and SWI-JACK, they were exactly the same directions. Again, I'd recommend getting the PAC thats meant for your head unit, wired remotes are much more consistent than the RF or whatever the X uses.
56-ohm and 1xx-ohm resistor in series will NOT work attached to the brown/white wire. The adapter will not switch from steering wheel to HU in this configuration. Gotta give PAC a call tomorrow...
ivorton23
Sep 28, 2015 09:08 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
