In the process of replacing alternator today...but I'm stuck
In the process of doing my alternator now, shroud is removed, splash guard removed, AC compressor bolts loosened but I'm stuck on the 14mm bolt on the idler puller.
It's not budging at all. I hammered it pretty well, drenched it in WD-40, and spent a half hour trying but its not moving. The bolt is starting to get slightly rounded and I can feel an "oh ****" moment in the making. Getting real pissed so I figured I'd come inside and take a break. Anyone have any suggestions?
Finally that SOB came loose after letting it sit in WD-40 for an hour. Got quite a bit on the belt though, hopefully it won't cause any slipping when this is done...moving on now
Well, got the idler pulley bolt off using my jack handle as a breaker bar. Breaker bar for a brass not on a pulley?
Next I went to loosen the drive belt tensioner and sure enough, "Oh $hit"...
Busted finger and "insert choice 4 letter word here"
Things after that went pretty smooth. Spent less than 5 mins maneuvering the alternator...I turned the lower radiator hose up and towards the driver side which helped alot with space.
Everything is installed back into the car, just need to get a new drive belt tensioner, and might as well get a new belt as well. Anyone know a part #, or know where I can go for the tensioner? Trying to avoid the dealership but I have a feeling they might be the only one to have it.
Do you remember if they had it in stock or did you have to order it?
I also lost some coolant when disconnecting the hose, maybe a 1/2 pint...I can simply add the approximate amount of new coolant back to the reservoir, correct? No need to completely drain and fill?
Yea, you should be fine just filling it back up at the reservoir. Or, if the engine is cold, at the radiator cap. Over time your cooling system should burp out any air through the reservoir tank anyway.
What are the symptoms of a drive belt that is too tight vs. too loose?
Somehow my tensioner loosened up and was rattling around, but I think the pulley stayed in place. Just wondering what types of things I should be keeping an eye/ear out for if the idler pulley has moved out of place.
Now thats what I like to hear. I didn't spend 2.5hrs installing to go and blow $40 on a broken bolt. Either way, I guess its better than paying for the labor bc I'm sure they would have broken it as well and then charged me extra.
Rage Maximus
09-03-2015 12:26 PM
JMag90
08-25-2015 09:17 AM
