5th Gen Fog Lights
Old May 26, 2009 | 08:52 AM
Max_Man116's Avatar
5th Gen Fog Lights
i just installed some strobes in my headlights today and i want put a set in the fog lights does anybody know how to take the lens off the 5th gen fog lights?
Old May 26, 2009 | 09:41 AM
bigpopaj369's Avatar
so im not sure if u know how to remove fogs but is very simple.this link is full of pics and straight forward http://www.cardomain.com/ride/2076435/2 and once u get them out on each side close to the lense is a small phillips screw these were a pain to remove in mine so i loosened them and took a flat head and put it in between the lense and housing appl pressure to free the screws these must be removed or lense will not come out. once u get them out either bake them in the oven about 8 mins on 250 degrees or the fast easier way that i used, if u have a small handheld propane torch go around the housing near the lense bein carefull to not melt or burn the lense all the way around maybe 2 or 3 times now take ur flat head and work ur way around the lense prying up the lense (carefully) it takes a little effort compared to the headlight lenses. u may need to reapply heat a couple of times or pop them back in oven for a few mins if needed. when u do get them open remove excess glue from the lense and clear out the housing of loose glue.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
