Installing Mesh Air Dam Grill
Old Nov 24, 2001 | 01:08 PM
2000Max827's Avatar
Ok I read the post by Russ about how to install it, but how to you get those ****ing stupid tabs out, I don't have a "special tab remover" as he calls it or whatever that thing is and i can't get those things out for the life of me. Any help would be appreciated.
Old Nov 24, 2001 | 02:33 PM
Ludacris's Avatar
Don't do it that way, there's a simpler way.
Open your hood and look ahead of the radiator, there's enough space to lower the gutter guard down into the airdam area. If you can, get someone to guide it down for you as you lower it.
Then just attach with the tie straps and finished.
Old Nov 24, 2001 | 03:28 PM
2000Max827's Avatar
I tried..it's too big to fit that way.
Old Nov 24, 2001 | 03:46 PM
RussMaxManiac
Flathead screw driver, and needle nose, and be super careful I used the needle nose to pry them out after the flathead got enough space for them to fit. Just be careful doing it this way, you can break those tabs easy.
Old Nov 24, 2001 | 04:17 PM
PhatGuy
It should work fine like Ludacris said assuming you have the real Gutter Guard?
Old Nov 24, 2001 | 04:55 PM
the paragon's Avatar
try not to yank out the tabs too hard. I kinda had trouble putting them back.
Old Nov 24, 2001 | 05:33 PM
2000Max827's Avatar
I got it in, I did it through the top. One more question, how do you secure the mesh on the bottom, where the two little rectangular shaped holes are?
Old Nov 24, 2001 | 08:20 PM
I believe you use those plastic straps and tie them down with where the dam is. There's 4 that you can tie them to.
Old Nov 24, 2001 | 08:21 PM
2000Max827's Avatar
No I mean below that...there is nothing to tie it on to. Any ideas from anybody?
Old Nov 24, 2001 | 08:56 PM
Greg's2kGLE's Avatar
I just zip-tied my grill to the 4 "posts" in the lower grill.
Old Nov 24, 2001 | 08:57 PM
Here is a pic. You can sort of see the zip-ties....
Old Nov 24, 2001 | 09:09 PM
2000Max827's Avatar
ok take a look at this pic and see where the 2 red circles are. Is there anyway to attach the grill there?
Old Nov 24, 2001 | 09:59 PM
yes, use FOUR additional plastic strips and tie them near the bottom so it supports the top as well. Just the same thing you did on top, do the same for the bottom. so end up having 8 tied strips together.
Old Nov 24, 2001 | 11:10 PM
Ludacris's Avatar
I think he mean't the 2 horizontal slots under the airdam...not really a way of attaching there, even if you did it wouldn't show up unless you got real close to it..
Old Nov 24, 2001 | 11:22 PM
2000Max827's Avatar
Finally, someone who understands me...lol...thanks for all the info guys I really appreciate it. I set it up and it looks nice. Next, my indiglo door steps go in. Can't wait. Anyone know if there is a 'How-to' yet on how to install them? Any info would be great.
Old Nov 27, 2001 | 09:17 PM
theMax's Avatar
installed with hiden zip ties
I did my install and you can't see the zip ties!
I used a cable tie holder (peel and stick on one side and a loop on the other) and stuck them above and below the opening. Then the zip ties are out of sight.
pic of grill install
Old Nov 27, 2001 | 09:23 PM
no picture
vingodine
45
May 21, 2016 12:46 PM
cruce91
Sep 20, 2015 10:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
