2K AT Substitute MT Motor Mounts?
Old Jun 15, 2009 | 02:20 PM
lxrmax's Avatar
I have a 2000 Maxima GXE with AT and a broken front motor mount (233K miles). To replace both front and rear motor mounts with the OEM electrical mounts is $355 versus $153 for the MT versions. Given the age of the car, I doubt it's worth it if the MT mounts/bushings will work OK.
Other threads suggest that replacing the AT crossbar and mounts with an MT crossbar and mounts, replacing only the bushings, is feasible, but those MT assemblies are reportedly scarce.
Does anyone know if it is possible to replace the OEM mounts/bushings for MT versions without the electrical bushings?
TIA
Richard
Old Jun 15, 2009 | 09:13 PM
Love_00_Max's Avatar
If you seached the forum you will find that it indeed is helpful to stick in MT mounts. I just did it and don't see much of a difference other than an occassional surge when the throttle is engaged quickly... I have 165K and did it primarily to save my ECM since another forum member shot his ECM when the mounts failed (some kind of a short).
Old Jun 15, 2009 | 09:22 PM
arthur glazier's Avatar
I did it also, call Dave b, and he will get you a much lower price. I have posted along with other about this topic, search and you will find.
Old Jun 16, 2009 | 11:06 AM
djfrestyl's Avatar
Suspension Yoda
You don't need to replace the crossmember.
www.rockauto.com - they have OEM replacement parts as well.
Old Jun 16, 2009 | 01:34 PM
http://forums.maxima.org/5th-generat...w.rockauto.com - they have OEM replacement parts as well.
The x-member holes line up with the AT mount holes... No need for a new x-member.
Old Jun 16, 2009 | 04:54 PM
djfrestyl's Avatar
Suspension Yoda
^^^ Is there an echo in here?
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
