Oil leak - am I in trouble based on these pics?
WOW that oil pan was seriously rusty... I thought mine was bad (no holes)...
Those damn stickers were a pain in the a... I left them on like that too, I figure they will probably just burn off or fall of when they get wet
I think I'm good on the rear main seal...transmission remains clean. I'm gonna do the OPS and oil cooler o-ring soon just for good measure and since they're cheap, but that pan was probably the main culprit.
The grayish bolts under the control arm has brown stuff that looks like oil. Not sure what other fluid that can be.
My pan is still in definite need of replacement (just gotta figure out a way to get the rounded bolt out without breaking it) but something tells me it won't fix the problem. There's oil all up in that area.
I was laughing at the speak english like Damn!!
I believe he means silicone RTV gasket material. Just use a small bit of this to keep the gasket in place while installing. The gasket will likely move out of place when installing if you don't use some RTV to seat it to the pan.
kjlouis
Oct 3, 2015 05:29 AM
bryants95max
Oct 2, 2015 12:52 PM
ag90fox
Sep 9, 2015 12:22 PM
