Ordered KYB GR2s what else to get?
Well I just ordered my struts on eBay and they should be here next week. I know my mounts are probably bad too there are some on eBay for pretty cheap are those ok or is it better to get oem? What else do I need to buy while I'm waiting for the struts to get here? Will i need new dust boots? Bump stops? Spring isolators? I'm sorry if I sound like a noob but I've never done struts before and i want to be prepared so I can get the job done without all the running around. I will be renting spring clamps too but what other parts/tools will I need to complete the job?
Go for Moog mounts. Better than OEM and who knows what you might get on EBay.
For a 2003 Max
Fronts are Part Number K90655 and includes the bearing
Rears are Part Number K90299
They also have Strut Bellows which includes the bumper
Front K90463
Rear K90467
Hope this helps.
For a 2003 Max
Front K90463
Rear K90467
Hope this helps.
That does help thanks. I found all those parts on ebay and they are on the way, thanks again
For a 2003 Max
Front K90463
Rear K90467
Hope this helps.
For a 2003 Max
Front K90463
Rear K90467
Hope this helps.
do those part numbers come with both sides? or do i need 2 of each? damn if i need (2) thats going to be $300
edit: I thought $150 shipped for mounts and belows on all 4 corners was an alright deal but now i realize it only comes with one side so i had to order everything a second time damn! well i guess i have some good quality $300 mounts & belows lol
$39.89 + $9.22 each for the rear moog mounts k90299
$17.58 + $8.91 each for the front belows k90463
$19.85 + $8.91 each for the rear belows k90467
that puts it a tad over $300 for everything but i messaged the company to see if i can combine shipping since i bought 2 of everything
You might want to check on the sway bar links also. While you have everything else off. That's where I was getting a lot of my noise from
The Moog's are thicker and have grease fitting compared to stock
Part Numbers are
K90432 for the left
and
K90431 for the right
After that the only other thing on the front for suspension is the balljoints
Glad I could help.
Part Numbers are
K90432 for the left
and
Part Numbers are
K90432 for the left
and
I'm running the MOOGS too and have enjoyed good success with them.
Also put on the Energy Suspension bushings on the sway bar up front.
dammit where was this info when i was looking for it!
I was thinking about buying Moog mounts but i saw the same model number being advertised for 6 gens as well.....went with KYBs instead
hopefully they wont give me any problems!
h&r's with kyb gr2's are pretty close to stock and pretty reasonable as far as price.
maxima-junky
Oct 7, 2015 06:13 PM
bigfrank
Oct 1, 2015 12:51 PM
