Pinging!!!
Old Nov 26, 2001 | 12:13 PM
Slothead's Avatar
Pinging!!!
I'm wondering if my digital knock sensor is working. My 2k 5spd pings on anything but Premium. Shouldn't the knock sensor kick right in and retard the timing. The dealer said if anything was wrong the dumby light would come on...any thoughts besides always using premium, I want to make sure it does work properly.
Old Nov 26, 2001 | 12:16 PM
Sprint's Avatar
did you read your owners manual? it says use 91 Octane.. now i figure since the manual says use 91.. i would use 93 since they don't sell 91 in my area..
what do you think?
Old Nov 26, 2001 | 12:35 PM
dufrane's Avatar
My 2000 5spd pings like crazy. This is using 93 octane. The dealer found no fault codes. And forget about trying to check the condition of the plugs.
Old Nov 26, 2001 | 12:36 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
I think SprintMax is right
The VQ30DE runs a relatively higher compression ratio that requires 91 pump octane fuel or higher.
Putting less than that in your Max would cause pinging, but you're right, the knock sensor should be picking that up and retarding the timing (with the side effect of dropping your performance and mileage) so that the pinging doesn't occur.
You might want to have Nissan take a look at that, but you shouldn't be running anything less than 91 octane in your Max in the first place anyways, so it's sorta besides the point, but not really
Old Nov 26, 2001 | 12:38 PM
SteVTEC's Avatar
If this is true then there is something seriously wrong with your car.
Old Nov 26, 2001 | 12:39 PM
Sprint's Avatar
the bad part about it is.. the dealers put 87 in the cars
Old Nov 26, 2001 | 12:40 PM
UMD_MaxSE's Avatar
Got Bent?
bad ignition coils.... I think there is a TSB on it now
Old Nov 26, 2001 | 12:43 PM
SteVTEC's Avatar
really?!?!? That sucks!
More Nissan retardisms...
Old Nov 26, 2001 | 12:46 PM
dufrane's Avatar
Thanks for the info UMD,
The pinging started at about 30K, and has steadily gotten worse. The previous driver drove it hard, but did not cause this problem. If I could get to the plugs it would probably confirm what you said.
Old Nov 26, 2001 | 01:01 PM
Slothead's Avatar
Where can I get TSB on Ignition coil?
Old Nov 26, 2001 | 01:05 PM
Sprint's Avatar
http://forums.maxima.org/showthread.php?threadid=29351
Old Nov 26, 2001 | 01:08 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
No one has a copy yet.
Old Nov 26, 2001 | 01:15 PM
Sprint's Avatar
sorry my maxima doesn't have such problems
fastcarny
Oct 6, 2015 10:42 AM
blizz20oma
Aug 30, 2002 01:15 PM
mtman74
Jul 22, 2002 09:41 AM
butternugtz
Jul 2, 2002 10:56 AM
Redmax
Mar 12, 2001 09:54 AM
