A/C Problems
Old Jul 10, 2009 | 08:50 PM
soxruled0's Avatar
A/C Problems
OK so here is the story. My 00 Maxima has always had great A/C and heating and the fan would always blow allot of air. But now its Blowing hot air when the entire climate control is off I know I need a recharge, but I don't understand why its blowing heat on me and its almost to hot to drive the car for a long distance because it gets so hot. It feels like there is no firewall. It is extremely frustrating and would appreciate any sort of help. It also seems like the fan motor is going bad because its not blowing as hard as it used to.
Old Jul 10, 2009 | 09:51 PM
Derrick2k2SE's Avatar
When the fan is on can you still switch between the different vents like defrost, upper, and feet?
Also, can you tell if the compressor is coming on?
It sounds like the vent doors that direct the air might not be working properly. They're controlled using engine vacuum and direct the air to flow over the heater core or the AC. Vacuum also controls the flow to the different vents. The problem could be as simple as a vacuum leak.
Old Jul 11, 2009 | 12:20 PM
soxruled0's Avatar
I can rotate all of the fans to the feet and everything but its just extremely unbearable to drive. I'm pretty sure that the compressor comes on because the air that comes out is cool but not like a/c cool its just cooler air then what is coming through the vents before I turn it on.
Old Jul 11, 2009 | 01:02 PM
Col Ronson's Avatar
hard to say. maybe the air vents are stuck open. Try running it on recirculation mode to see if that stops fresh air from coming in.
Old Jul 11, 2009 | 01:23 PM
soxruled0's Avatar
Ya ill try that that's a good idea.
Old Jul 11, 2009 | 07:58 PM
soxruled0's Avatar
Ok so I used the recirculation mode. It stopped the hot air from coming in but is there any way to fix the hot air that is coming in my self?
Old Jul 12, 2009 | 07:26 AM
PadawanKnight's Avatar
When the climate control system is completely off, the air you feel is fresh from the outside. It's the summer, so more than likely it's going to be hot. Do the same thing in the winter and it'll be cold.
Putting the system into recirculation mode closes the vents to the outside, so you shouldn't get any movement of air.
Old Jul 14, 2009 | 07:19 PM
soxruled0's Avatar
OK fair enough I just made my self look like an idiot. So I should go and get my A/C recharged and that would fix the problems you think?
Old Jul 14, 2009 | 08:56 PM
I think having the A/C inspected and recharged would be your best bet at this point.
Old Jul 15, 2009 | 07:18 AM
I'd have to agree. Take it somewhere and have it inspected. There's usually not a lot you can do to an AC system without the proper tools and equipment.
In fact, you can turn a simple repair into a very expensive one by messing with it. Overcharging, undercharging, not vacuuming the system properly, not having enough oil etc... can all cause more problems. The problem may even be caused by a blockage and not a leak. If so, adding more refrigerant can cause serious(expensive) problems with the system.
Old Jul 15, 2009 | 01:27 PM
soxruled0's Avatar
OK, Thanks guys I made an appointment at my local shop to look at it. Ill keep you guys informed.
Old Jul 15, 2009 | 05:32 PM
ravis1019@gmail.com's Avatar
A/C diagnosis w/ auto climate control
If you have an auto climate control you can run the self diagnosis. By turning the car on and then immediately hold down the OFF button on the climate contol, you'll see all the lights light up and then you turn the temp **** to right to check all the sensors that are associated with the A/C, turn the right again and then it will check the motor doors position checked, turn right again and then actuators check, turn right again and then you can see the output of all the sensors(ambient temp, inside car temp, outside) by using the fan speed buttons. On the first(sensor check) and second(motor door position) check if the codes come up. 1st check you will see a 2 wait 25 seconds and a second number will appear, If a 0 comes up *(20)* all the sensors are fine, second check will appear a 3 you'll have to wait around 50 seconds to check all the air mix door etc. and if a 0 appears. your problem will be to add coolant and you have to do it by temp. and Since I live in Miami, fl it was 89 so i had to put about 32 psi. PS do this test in sun light or if its done in a shadowy area you'll get a error on the first test which is for the sun load sensor on the passager side of the dash board.
BkGreen97
Apr 2, 2016 05:47 AM
Turbonut
46
Oct 21, 2015 08:28 PM
mclasser
Sep 24, 2015 11:57 PM
pears
Sep 18, 2015 05:25 AM
EdRomo86
Sep 12, 2015 07:49 PM
