Can this be done?
Old Jul 12, 2009 | 09:40 PM
viperboy's Avatar
Can this be done?
Can you make the rear windows and sunroof open when pressing and holding the unlock button on the fob instead of just opening the front windows? What would need to be rewired or modded? Would be really useful to me.
Old Jul 12, 2009 | 09:59 PM
knight_yyz's Avatar
Toolie
accessory button on an aftermarket alarm system would work if wired properly
Old Jul 12, 2009 | 10:07 PM
viperboy's Avatar
Couldn't you just rewire some things to where ever the fob goes and make it put the rest of the stuff down?
Old Jul 12, 2009 | 10:11 PM
BigOgre's Avatar
Can i make my windows roll down in a 5th gen?
Old Jul 12, 2009 | 10:29 PM
Col Ronson's Avatar
it doesn't work like that. I was going to rebuild my engine to make it run on water too, but haven't found the instructions for that either.
Old Jul 13, 2009 | 05:38 AM
LA02MAX's Avatar
I doubt you can get the sunroof to open since it has a fixed switch (ie: it matters what happens with it even when the car is off; if you move it, it doesn't return to its original position). However, the rear windows shouldn't be terribly difficult if you can locate a wiring diagram of the alarm system.
Old Jul 13, 2009 | 05:55 AM
321VQ35MAX's Avatar
It is possible. On Lexus and BMW the sunroof opens as well. You have to go aftermarket, but can be done.....
Old Jul 13, 2009 | 06:43 AM
Derrick2k2SE's Avatar
I don't have the link any more but there was a company that made a circuit you could wire in. It would let you control other things with the factory remote. You could roll all the windows up and down and control the sunroof.
Old Jul 13, 2009 | 09:05 AM
Col Ronson's Avatar
yes the only way to do it is aftermarket.
Old Jul 13, 2009 | 10:28 AM
xWasX08's Avatar
If you already dont know, look into Viper Alarm Systems.
Old Jul 13, 2009 | 11:19 AM
viperboy's Avatar
If you had the info on this, I would love to see it if you could find it. I was hoping someone had done something similar already. I didn't find anything though.
Old Jul 13, 2009 | 11:35 AM
viperboy's Avatar
This would be good for the making the windows go up. I linked to the PDF instructions because you can't directly link to the product. I wish there was a way to integrate the rear windows into it atleast.
http://www.kptechnologies.com/docs/N...stallation.pdf
Old Jul 13, 2009 | 11:37 AM
viperboy's Avatar
http://tinyurl.com/nbecnu
LA02MAX's Avatar
Like I said, find a wiring diagram (maybe in and FSM..can't view it right now since I'm at work) of the alarm system, and it's possible you just need to splice the wires from the rear windows into it...
Old Jul 13, 2009 | 11:41 AM
viperboy's Avatar
I'm sure that would work, I was just hoping someone had done it already that actually knew what to do
Old Jul 18, 2009 | 01:43 PM
xxclusive's Avatar
any response to this ?
can i do this from the factory remote ?
Old Jul 18, 2009 | 01:47 PM
02SEMax's Avatar
sure, hold the unlock button and the front windows roll down, you may have to press more than once though, but just hold the button
Old Jul 18, 2009 | 02:21 PM
maxdriver10's Avatar
the rear windows cannot be made to roll all the way down if thats what you were asking. Has to do with the shape of the door and its position relative to the rear wheel wells
Old Jul 18, 2009 | 04:10 PM
Nelsito65's Avatar
That feature is not present with the factory remote on 5th gens. Unless you are referring to some kind of rewire.
Old Jul 18, 2009 | 05:24 PM
AEMAXIMA01's Avatar
The remote fob window roll-down feature was skipped on the 00-01 for some reason. I wish I had it on mine....
Old Jul 23, 2009 | 01:25 AM
CARLOS9827's Avatar
I was just going to say that its only on 02-03 models....
Old Jul 25, 2009 | 01:02 PM
MysticCBR's Avatar
just like others are saying aftermarket will do it all ...there is a special module for the sunroof thou
